'98 S70 Strut Replacement Woes
firekiller75
Year and Model: 1997 850, 1998 S70
Post by firekiller75 »
Went to replace my struts, spring seats, strut mounts yesterday. Ended up unable to because I couldn't loosen the top nut from the strut shaft!
Now keep in mind that I don't live in the rust belt. That being said, the car has 186k miles, and i believe the suspension parts to be original.
I sprayed plenty of WD-40 and let the nut sit a while. It won't budge! I have now pretty much rounded off the top of the strut shaft. I tried it in the car, out of the car with the spring compressed, then in the car once again. It hasn't budged!
Once I rounded off the top of the shaft, I beat a 10mm combination wrench end on it, slipped a cheater bar over the wrench, then turned. It bent then broke my Craftsman combination wrench! I mean the nut is on there!
Not sure what else to try. My thought was to use a reciprocating saw and cut the strut shaft with the spring compressed.
Suggestions?
Thanks, Adam.
'98 S70 n/a with 187k miles, paid $300 for it!
'97 850 n/a wagon, girlfriend's cruiser!
Previous Volvos:
2001 S60 2.4T
1993 240 DL
1986 240 2-door
1984 240 4-speed w/overdrive button
scigarzz
Year and Model: 1998 s70 glt
Post by scigarzz »
if all else fails, maybe a chisel and a hammer !
firekiller75
scigarzz wrote:if all else fails, maybe a chisel and a hammer !
You mean to break the nut?
Previous Volvos:
2001 S60 2.4T
1993 240 DL
1986 240 2-door
scigarzz
Post by scigarzz »
yes, to break the nut, i've done this a few times. just make sure if you use this method, start a groove on the flat part of the nut, and hit it off the shaft.
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 19 times
Post by jblackburn »
PB Blaster, monkey wrench as tight as you can get it on there, and something to push against! You could try hitting it with a sledgehammer a few times to attempt to loosen it...just don't miss!
If not, then I guess you'd have to Sawzall it!
'98 S70 T5
2016 Chevy Cruze Premier
firekiller75
jablackburn wrote:PB Blaster, monkey wrench as tight as you can get it on there, and something to push against! You could try hitting it with a sledgehammer a few times to attempt to loosen it...just don't miss!
I saw reference to the monkey wrench in a how-to I read. I guess I am confused about the monkey wrench. I'm just using a 21mm wrench on the nut. Where are you folks putting the monkey wrench?
Previous Volvos:
2001 S60 2.4T
1993 240 DL
1986 240 2-door
Year and Model: Many Volvos
Been thanked: 75 times
Post by Ozark Lee »
I use a pipe wrench and a cheater pipe to get the cross shaped nut loose but you are not there yet.
I have used a nut cracker on similar problems. I'm not sure how well a sawzall will work, I think the strut shaft is case hardened and it will likely just shine the shaft as it eats the teeth off of the blade.
firekiller75
Ozark Lee wrote:I use a pipe wrench and a cheater pipe to get the cross shaped nut loose but you are not there yet.
Lee, gotcha, thanks. Definitely clears things up. Forgot about a nut cracker, think I've used those before with success. I'll pick one up on the way home today. Thanks!
Previous Volvos:
2001 S60 2.4T
1993 240 DL
1986 240 2-door
firekiller75
Man that strut was the worst ever!
Pulled the strut back out, compressed the spring, tried again for fun, no joy. Worked on the nut with a Craftsman nut cracker, broke it (OMG!), which is when I realized the nut had a shoulder on it!
SOOO... Took a hack saw to the nut, just about the shoulder, and cut it/shaft off. Then put the remainder on an angle grinder for a bit and presto, it was gone! The cross-shaped nut was actually just finger tight (weird!).
After all that, the darn spring seat wasn't even broken or worn looking! Not sure how that could be after 182k miles! In fact, I saw no wear/tear on the seat or mount other than the fact that the entire assembly would spin pretty freely when still mounted in the car.
Short story long, the assembly has been replaced and my clunking is completely gone! At least all my effort did not go unrewarded!
Previous Volvos:
2001 S60 2.4T
1993 240 DL
1986 240 2-door
dbo550
Year and Model: 95 T5-R, 98 V70
Post by dbo550 »
Where did you order your parts from? How much did the parts cost? glad you finally succeeded.
