1998 S70 GLT - Multiple Repairs Needed
pauleads
Post by pauleads »
I like my car (104,000 miles) a lot but all of a sudden things are starting to go wrong with it. I've given some thought to trading it in, getting what I can for it, and not doing any repairs but I'm attached to it so I'm going to bite the bullet on some repairs. I need some good advice on the following repairs. Which ones would you do first? Do the prices seem fair, etc.
-- ABS Control Unit $700
-- Right front Strut $170
-- Valve ticking off and on. Repair shop recommends removing oil pan for inspection of seal rings on oil pickup tube approx. $500
-- auto door locks won't open. You have to manually lift the lock and use key in door. No price yet as I didn't have them look at that. Any idea what that might be?
Any advice is appreciated.
will bj robinson
Year and Model: 850, 1995. 98, S70 g
Post by will bj robinson »
look around on this site there are people who can repair the ABS module. there is also a detailed writeup on how to do it yourself. As far as the strut, replace both sides at the same time if ones bad the other isnt far behind. that price seems right (as long as the parts are included) as for your doorlocks did you try changing the fobs battery?
95 850 turbo....poly upper mount, 19t turbo, 3" downpipe, 2.25 custom exhaust w/magnaflow cat. bilstein struts/shocks,Ipd hd mounts and seats. vented cross drilled rotors F/B. and lastly an Alpine H/U,and hopefully more to come!!!
polskamafia mjl
Has thanked: 19 times
Been thanked: 21 times
Post by polskamafia mjl »
+1 Will. If you are not willing to do the ABS yourself then at least read the thread about the ABS Module repair and send it to Vic. He will fix it for $150 NOT $700. That's ridiculous. Struts need to be done at the same time so that goes up to $340. As far as the central locking, replace batteries and try it out. If that doesn't fix it then read the thread on this website about the central locking.
pauleads
Post by pauleads »
polskamafia mjl wrote:+1 Will. If you are not willing to do the ABS yourself then at least read the thread about the ABS Module repair and send it to Vic. He will fix it for $150 NOT $700. That's ridiculous. Struts need to be done at the same time so that goes up to $340. As far as the central locking, replace batteries and try it out. If that doesn't fix it then read the thread on this website about the central locking.
Thanks for the help. I read the thread that detailed the ABS module repair and it seems fairly straighforward; however, having never soldered or repaired an ABS module I'd prefer someone who know what they're doing to do the job. I thought $700 seemed high. BTW -- who is Vic?
pauleads
Post by pauleads »
will bj robinson wrote:look around on this site there are people who can repair the ABS module. there is also a detailed writeup on how to do it yourself. As far as the strut, replace both sides at the same time if ones bad the other isnt far behind. that price seems right (as long as the parts are included) as for your doorlocks did you try changing the fobs battery?
Yes, I've changed the battery in the fobs. Even when I try to use the power unlock button on the inside of the door (the one that unlocks all doors at the same time) it doesn't unlock the doors either.
polskamafia mjl
Take a look at this thread -> https://www.matthewsvolvosite.com/forums ... ng#p104136
Vic Rocha I think is his name, he repairs the ABS modules. He has a website detailing how to remove the ABS module so you can send it to him to fix.
In your first post you mentioned your mileage to be around 100k and you said that everything seems to be falling apart. The 100k milestone is typically when a lot of things need to be replaced. If you keep the car long enough, you will run into a similar situation at 200k, 300k, etc... lol
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 20 times
Post by jblackburn »
The door locks are a PITA to fix, but can be done pretty easily yourself. I'm assuming you still hear the motor in the door run when you push the unlock button, right? If someone holds the handle on the door while you are unlocking it with the remote, it breaks the plastic tab in the door that connects to the motor to push the locks up and down. You'd think between all the car manufacturers out there they'd think of a better design...
Everyone else covered the ABS module.
Both front struts need to be done at the same time.
As for the oil pickup lines, before you do that, try running some Seafoam through your engine. $10 for a can, and can help with valve noise, and dramatically improve how well your car runs. 1/3 in gas tank, 1/3 in oil, and 1/3 through a vacuum hose. Search the site for 'seafoam instructions'
'98 S70 T5
2016 Chevy Cruze Premier
renns
Year and Model: 2005 XC70
Has thanked: 3 times
Been thanked: 6 times
Post by renns »
jablackburn wrote:As for the oil pickup lines, before you do that, try running some Seafoam through your engine. $10 for a can, and can help with valve noise, and dramatically improve how well your car runs. 1/3 in gas tank, 1/3 in oil, and 1/3 through a vacuum hose. Search the site for 'seafoam instructions'
Before running that stuff through your engine, read this thread:
https://www.matthewsvolvosite.com/forums ... =1&t=13217
My top end noise started AFTER using that product...
1994 850 5-speed wagon, retired at 400,000 km
1998 V70 AWD 5-speed, retired at 358,000 km.
2005 XC70 275,000 km - daily driver
polskamafia mjl
Uh oh...I sense a seafoam debate. I am w/ Jackblack about the seafoam...once this spring/summer comes I plan on seafoaming my engine.
renns
Post by renns »
No debate intended, just a warning. I wish I'd had that warning prior to doing mine. That thread should be sticky IMO.
