1999 S-80 T-6
1999 S-80 T-6
Where is the PCV on a 1999 S-80 T-6? I have replace the black box along with the hoses in front below the intake. I have an oil spray coming from the dip stick tube. Can u help?
- billofdurham
- Year and Model: 855, 1995
- Been thanked: 5 times
The attached is the PCV for the S80.
If you are looking for a flame trap, which does cause problems with oil spray if it is dirty, turbo models don't have one. The oil trap and all pipes should be checked for a build up of grunge and cleaned if necessary. One of the most common faults is blocked nipples
Also check the pipework to the turbo. Common problems are perished rubber elbows and blocked pipes.
Bill.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Previously:
- 1643 Views
Last post by precopster
- 12 Replies
- 2982 Views
Last post by CNGBifuel
