'98 S70 Check Engine Light Mystery
firekiller75
- Year and Model: 1997 850, 1998 S70
So I went to both Autozone and Advanced Auto today, and they were unable to read my CEL off my OBD-II connector. Seems very bizarre to me, which is why I went to a 2nd place. Anyone have any suggestions? I guess I could pull the center console to check the wiring, but other than that, I'm at a loss!
'98 S70 n/a with 187k miles, paid $300 for it!
'97 850 n/a wagon, girlfriend's cruiser!
Previous Volvos:
2001 S60 2.4T
1993 240 DL
1986 240 2-door
1984 240 4-speed w/overdrive button
Previous Volvos:
2001 S60 2.4T
1993 240 DL
1986 240 2-door
firekiller75
Wish it was so simple!
The auto parts stores were unable to get any signal at all from the OBD-II connector.
Previous Volvos:
2001 S60 2.4T
1993 240 DL
1986 240 2-door
Previous Volvos:
2001 S60 2.4T
1993 240 DL
1986 240 2-door
firekiller75
Bah... Totally not what I want to hear. Was looking for a response like "I had the same problem, and when I replaced this certain fuse, not only did my OBD-II work, my car ran like new!"FCPGroton wrote:This may not be what you want to hear, but I would bring it to Volvo to see if they can read codes from the OBDII port.
That would be nice...
Previous Volvos:
2001 S60 2.4T
1993 240 DL
1986 240 2-door
Previous Volvos:
2001 S60 2.4T
1993 240 DL
1986 240 2-door
firekiller75
So no one else on the board has ever had this issue?
Previous Volvos:
2001 S60 2.4T
1993 240 DL
1986 240 2-door
Previous Volvos:
2001 S60 2.4T
1993 240 DL
1986 240 2-door
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
If the center console has ever been removed for any reason, it's possible some of the wiring for the OBD connector was pulled out of the sockets for the connector. Have you ever been able to pull codes on this car before? If the Volvo dealer itself can't pull codes, they shouldn't be able to charge you for anything...but they probably will.
The 4WD transfer case in my dad's Jeep was replaced under warranty, and after spending almost a week with parts on order, the idiots at the Chrysler dealer "forgot" to plug the switches in the console back in for the electric windows, which they left down. There was actually a wire hanging out from under the stupid thing.
'98 S70 T5
2016 Chevy Cruze Premier
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 94 times
- Been thanked: 146 times
+1 for an unplugged OBDll socket. That's about all I can think of, too.jablackburn wrote:If the center console has ever been removed for any reason, it's possible some of the wiring for the OBD connector was pulled out of the sockets for the connector. Have you ever been able to pull codes on this car before? If the Volvo dealer itself can't pull codes, they shouldn't be able to charge you for anything...but they probably will.
Any common OBDll reader should pull the basic codes with no problem.
I'd go with pulling the console and having a look. Let's hope it's that simple!
- 2201 Views
Last post by Ozark Lee
- 6325 Views
- 2765 Views
Last post by Georgeandkira
- 2587 Views
Last post by theWIFES_S70
- 2928 Views
Last post by JLGParis
