busted oil cooler adapter
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
wdshea
Year and Model: 960 96
Post by wdshea »
i need a new oil cooler adapter. does the 960 oil filter stick straight down?
my oil filter sticks out sideways off of an adapter. it looks like i could delete the adapter if i had the right threaded fitting to accept the filter.
is anyone familiar with this?
bright
Year and Model: 1995 960
Post by bright »
wdshea wrote:i need a new oil cooler adapter. does the 960 oil filter stick straight down?
Can you send pictures? I really can't understand what you are saying and why you need to do this. Please explain more.
Bright
Many Thanks,
Bright
1995 960 Sedan
wdshea
Post by wdshea »
bright
Post by bright »
Wow, I have never seen this before. Is this for a heavy duty engine oil cooler?
What's wrong with this one? It might be fixable.
Many Thanks,
Bright
1995 960 Sedan
wdshea
Post by wdshea »
i've never owned a volvo before so i assume it's standard issue.
the guys at my local volvo shop sold me a used one they salvaged.
there were no seals in the adapter, and the oil cooler has a pin hole in it because apparently the previous owner bottomed out on something.
i have a lot of confidence in JB Weld, but on something so crucial I'd hate to damage the engine over $45.
bright
Post by bright »
ask one of the moderators directly. They are always looking at the posts and can give you a better answer than I can at this point.
Wish I could help,
Lee
Many Thanks,
Bright
1995 960 Sedan
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
It is standard on '94 to '97 models. '92 & '93 models had a different oil cooler which didn't include the filter. On those two years the filter did point down.
A new oil cooler can be found here. Rather expensive!!
You could try Erie Vo-Vo, link at the top of the forum. Phone rather than email. I believe they are very knowledgeable and helpful.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
DanR
Post by DanR »
Where is the pin hole, on the oil side or the coolant side?
There are o-rings that seal the coolant housing from the oil section. Can you get this from a junk yard?
If it is the coolant side, you could bypass the cooler I suppose, not sure what that might do to the oil temp on a hot summer day. But then, the engine is originally spec'd for conventional motor oil, with synthetic, you might have some leeway on temps.
DanR '94 964 346,000 miles (112,000 on the new engine)
wdshea
Post by wdshea »
i already found a replacement at my local independent volvo shop for $45.
just trying to share what i've found.
bright
Post by bright »
Thank you for letting us know how it turns out. Many times people don't post the results, which is a bit disappointing. The board is about disseminating information.
I do not wish to engage in the synthetic versus natural oil debate, but it would make no difference. You've done the correct thing.
Good Luck,
Bright
Many Thanks,
Bright
1995 960 Sedan
