940 1994: Belt chirps no more
This topic is in the MVS Volvo Repair Database » 940 Belt chirps - replace auxiliary belts, alternator bushings
writer100
Year and Model: 940 1994
Post by writer100 »
For some time I had been noticing that one or more of my drive belts was squeaking. Not the loud squeal of a loose belt, but more of a chirping sound, like a talkative squirrel. :) Whenever I was picking up my car from valet parking (in this city, you have to valet nearly everywhere) I could always tell by the chirp-chirp when my car was coming being brought around. Upon examining my alternator pulley, I noticed that it was slightly out of plane with the crankshaft pulley. The alternator bushings appeared to be crushed due to age and heat. At 70,000 miles since last change, my belts were due as well.
The car is equipped with three drive belts: one for the air conditioner, one for the alternator, and one for power steering and the water pump. I ordered three new Continental belts from the Autohaus for $35.43. My local Volvo dealer, Galpin Volvo, was happy to provide me with new alternator bushings for the sum of $27.33.
This is a pretty straightforward job. The 940 is equipped with belt tensioners which make the job easier. (My old 240 was not, which required using a pry bar in one hand, while tightening with a socket in the other.) Here's the steps I followed:
1. Spray all bolts the night before with PB Blaster.
2. Make a diagram of the belt order, size, and orientation.
3. Use six point sockets to avoid rounding off nuts and bolts. Each of the accessories has three different kinds of fasteners: mounting nuts and bolts (12 and 13 mm), which holds the accessory in place, fixing bolts (13 mm), which anchors the accessory at the correct tension, and tensioner bolts (10 mm), which allows tension to be applied and released.
4. The only challenging nut to get at is the rear fixing nut for the air conditioner compressor. I used a universal extension to reach it. For each of the three accessories, once the fixing nut was loose, I turned the tensioner bolt counterclockwise several turns. This released tension from belt. I grabbed the belt and move the accessory inboard to create more slack.
5. It is neither possible nor necessary to completely slacken the belts. Just get them reasonably loose. Then use a 25 mm socket on a breaker bar to turn the engine over, while pulling the belt off the pulley. (Watch your fingers.)
6. With all the belts removed, I slid out the alternator bushings. Just as I suspected, the bushings were completely trashed. The new bushings are a pressure fit. I used silicone spray to lubricate them. (Careful not to overspray this in the engine compartment.) All but one could be installed by hand; for the other, I used a set of channel locks.
7. Put the new belts on by turning the engine over with one hand while using a pry bar with the other.
8. Add tension to the belts by turning the tensioner bolts clockwise. I tensioned them to roughly 1/2" of deflection. Then tighten the fixing nut.
9. Finally, turn the tensioner bolts counterclockwise a turn or so to unload them. The fixing bolt should carry the load -- not the fragile tensioner bolt.
With the installation of the new bushings, the alternator pulley appeared to be correctly aligned with the crankshaft pulley. This conclusion was confirmed by the disappearance of the chirping sound of the belt. :D
The tools I used
The tools I used
Alternator mount with bushings removed
General belt orientation
1994 Volvo 940: 189,000 miles.
2008 Mustang GT convertible: 10000 miles. The garage queen.
bright
Year and Model: 1995 960
Post by bright »
Nice Job! I'm surprised others haven't commented yet. When I was young (all of 18 years ago) I would rebuild my generators in my VW's. They were not alternators, so there were issues with brushes. You could buy the whole kit for a couple of bucks.
I like seeing a fix-it solution. Good job.
Happy New Year!
Bright
Many Thanks,
Bright
1995 960 Sedan
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
I'm not surprised. I was in bed when this was posted.
Good write up which I am putting into the Repair Database.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Bandit
Year and Model: 2008
Post by Bandit »
You think Volvo would have learned by now. My old 240 wagon had the same problem with the power steering pump. I finally replaced the bushings with a kit from IPD who made them out of urethane which are stiffer and would not deteriorate like the rubber does on a Volvo. Nice fix however and hopefully no new problems for awhile.
Al
