Just as the thread name says, the best heat I can get in the Chicago 10 degree weather is luke warm at best. Sitting at stop light, all air goes cold. The blower works fine. Its just the temp of the air its pushing when the outside temp is very cold.
Suggestions???
Paul
01 S60 2.4t Luke warm heat
Old Blue 66
- Year and Model: 2001 S60 2.4t
confused_al
- Year and Model: 1996 TLA wagon
Sounds like your t-stat is stuck open, which you can tell if the temp wont stay at the half way and drops at higher speed.
96 850 Platinum Wagon
98 MB ML320
06 V70
95 850 GLT(RIP)
98 MB ML320
06 V70
95 850 GLT(RIP)
Old Blue 66
The heat temp or the engine temp??
The heat temp increases at high speed. Goes to nothing once stopped.
Paul
2001 S60 2.4t Owner 117,000 miles
confused_al
Its the engine temp. Another way to tell is that the top radiator hose should be nice and hot after driving for a few miles regardless outside temp. BTW, its always good idea to replace ECT every time replace t-stat.
98 MB ML320
06 V70
95 850 GLT(RIP)
98 MB ML320
06 V70
95 850 GLT(RIP)
Old Blue 66
Its hot, but I cant tell if its off the heat off the engine or from coolant flowing through.confused_al wrote:Its the engine temp. Another way to tell is that the top radiator hose should be nice and hot after driving for a few miles regardless outside temp. BTW, its always good idea to replace ECT every time replace t-stat.
I am experiancing the change in engine temp as you described.
What is the ECT?
Paul
confused_al
ECT is engine coolant temp sensor, which usually has similar lifespan as the coolant thermostat and cheap ($20).
So just go get your t-stat and ECT replaced you'll be warm again.Old Blue 66 wrote:I am experiancing the change in engine temp as you described.
98 MB ML320
06 V70
95 850 GLT(RIP)
98 MB ML320
06 V70
95 850 GLT(RIP)
Old Blue 66
Thanks for the advice. I appreciate it!!!!!confused_al wrote:ECT is engine coolant temp sensor, which usually has similar lifespan as the coolant thermostat and cheap ($20).So just go get your t-stat and ECT replaced you'll be warm again.Old Blue 66 wrote:I am experiancing the change in engine temp as you described.
Paul
Old Blue 66
I have heat!!!!!!! T-stat just like described!!. Wow that sucker gets hot.
Paul
confused_al
98 MB ML320
06 V70
95 850 GLT(RIP)
98 MB ML320
06 V70
95 850 GLT(RIP)
piercebrew
- Year and Model: 2001 S60 2.4T
Wow I have the same problem. I bought the parts, but How do I install them? Where are they located? I'm handy so I should be able to do it.
Thanks
Thanks
