why won't it start
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
ascmyworld
Year and Model: volvo 740 gl 90
why won't it start
Post by ascmyworld »
I have a 90 740 gl wagon. About a week ago while driving it just died on me. We checked the usual things to check. Still no start. Our neighbor looked into the oil reservoir and said the camshaft wasn't turning. Could this be the culprit or is it something else?
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 19 times
Post by jblackburn »
Camshaft wasn't turning? Sounds like a broken timing belt! Pull the cover off and look - luckily on these cars it doesn't destroy the whole engine :mrgreen:
What's the "usual" things you checked?
'98 S70 T5
2016 Chevy Cruze Premier
ascmyworld
put in gas, oil, fuses. general things. now this car had a new motor put in when i don't know was told that when i bought the car. everyone is asking (repair places) me if it is SOHC or DOHC? I can't find it so I do I know?
jblackburn
It depends what other kind of car the donor engine came out of. Yours came with the SOHC engine, but if it was replaced with a DOHC from the more powerful GLE model, that would change things.
I know that this couldn't be done between 8V and 16V Saab's of the same generation, but the wiring on the Volvo might be the same.
See if you can find me the engine serial number and I can run it through VADIS. It's stamped onto the block of most cars. I don't know the visual differences, if any, from the two engines.
'98 S70 T5
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
#1 is SOHC, #2 is DOHC.
The DOHC is an interference engine.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
ascmyworld
my car has been sitting for a week and I went out today to get the #'s and i couldn't get the hood open. it is tricky to get the hood latch to open it. by guess which i know isn't good it looks like a SOHC. I will have to find a way to get the hood open. Where is the best place to take it that isn't going to charge a crap load of money to fix it? or is it something you can do yourself?
jblackburn
If it's anything like my car, you'll have to have someone pull up on the hood (or push down, depending) while pulling the hood latch. The cable at the pull latch inside the car just needs to be adjusted, and the bumpers where the hood latches down are adjustable on some of the older cars - just not my S70.
If it's a SOHC, you're in luck! Your engine's not destroyed - pretty much any garage do a timing belt if their mechanics are any good, I had one done on an old Honda at a local tire place - and now that you know call around your area and get a couple estimates. Those old Volvo motors are very accessible, and it's probably very easy to do it yourself if you're good with a wrench!
The hardest part of a timing belt is getting the crankshaft marks to line up again. Pull the cover off and have a look around for yourself, and then you can decide whether to DIY or take it somewhere!
This write-up is for a 240, but it's the same engine you have.
http://www.stepbystepvolvo.com/Resource ... 0print.pdf
Be patient...it's a huge PDF, froze my computer for a minute
'98 S70 T5
ascmyworld
I would like to do it myself but i don't think all of my male family members think i could. I just can't seem to find someone that I can take it to. I have so far only got success with 2 places one was a Volvo guy and he wanted 285 next was Midus and it was quoted being DOHC $400+. We don't have money for this right now. So how do I know who should be right to do this? My father wants to but he is a wanna-be mechanic and i don't want him fiddling with this when he really doesn't know how to do it. Don't get me wrong I appreciate it but we need this car.
billofdurham
The step by step is very comprehensive but is for the non B230 engine, ie the B23 series. Whilst a lot of it can be used for the B230 some, especially with regard to the crankshaft pulley, is out of date.
Here are two links to do with replacing the belt on the B230. 2 or 7 series the procedure is the same.
Timing belt replacement B230 and Crankshaft holding tool.
Replacing the belt is straightforward and, apart from the holding tool, can be done with basic tools.
Bill.
Previously:
