I have a 1999 S70 Volvo that surges and runs rough for the first minute or two after a cold start. It has never done this before and just seems to have started after having it's timing belt replaced.
It's my wife's car and she also seems to think it is slightly down on power. Ideas?
1999 S70 rough running when cold
cityfarmer
- Year and Model:
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 19 times
Check for vacuum leaks or loose hoses before trying to troubleshoot something else. Once it's warmed up and idling normally, take a can of carb cleaner and spray around any vacuum lines you can find and see if it surges.
'98 S70 T5
2016 Chevy Cruze Premier
FlyingVolvo
- Year and Model: 2000 V70XC
- Has thanked: 51 times
- Been thanked: 73 times
Could be ETM related... Rough idle and surging are pretty common with that. Although you could try cleaning the Mass Airflow Sensor (MAF) first to see if that helps.
2000 V70XC - 340,000 miles
2023 V60 T8 PE
2023 V60 T8 PE
