2007 XC headlight washer fuse?
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
mdross1
Year and Model: V70 XC 2007
Post by mdross1 »
It's time to disable headlight washers.The manual shows that it is under the steering column at #34 position,hopefully it is there.The picture of the fuse block in the manual does not show a postion #34.Also concerned about working with plastic panels in this cold Maine weather.
otis44
Year and Model: 2006 S60 T5
Post by otis44 »
I don't know about the # on the fuse, but I think that panel will essentially be held on by two torx screws that you should be able to feel or see if you poke your head up in there. From recollection this panel is one of the easier ones inside the car to take on/off. Good luck
mdross1
Post by mdross1 »
Could someone tell me where this panel is.Looking under the steering wheel and around the footwell certainly is not obvious where the access panel is.
otis44
Post by otis44 »
mdross1 wrote:Could someone tell me where this panel is.Looking under the steering wheel and around the footwell certainly is not obvious where the access panel is.
If you've got your hand on the underside of the steering column, slide it downwards toward the gas pedal after a short distance move it left and right and you should be able to feel two torx screws (one on each side of the panel). The panel may have the footwell light in it as well. You remove these screws and from memory slide the panel down slightly toward the floor of the car and it should come out.
mdross1
Post by mdross1 »
Great,next time I get into a heated garage I will look for the torx screws.
