S60-D5 Blowing HOT & cold intermitantly.
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
ArtyH
Year and Model: S60-D5
Post by ArtyH »
Hello, I am new to the forum. I live in the U.K, we are experiencing a bit of bad weather at this time and this has shown me that I have a problem with my heating system. I have recently bought the car (its a 2005 SE 2.4 model) and did not notice the heating problem at the time of purchase and think the recent cold weather may be a factor.
The problem is when the heater is turned up to max and or any other setting the blower emits both hot air for about 3 seconds and then cold air for the same time. This result in the car reaching only a moderate interior temperature. The temp gauge reads halfway and is steady.
I have read a thread concerning the replacement of the thermostat -
https://www.matthewsvolvosite.com/forums ... 9&t=25928-
and wondered if it was the temp stat or the engine coolant temp sensor that could be the problem?
Any advice would be greatly appreciated.
Kind regards,
ArtyH.
confused_al
Year and Model: 1996 TLA wagon
Post by confused_al »
ArtyH wrote:...The temp gauge reads halfway and is steady
That doesn't sound like you have a bad ETC or t-stat problem.
ArtyH wrote:The problem is when the heater is turned up to max and or any other setting the blower emits both hot air for about 3 seconds and then cold air for the same time.
That sounds like you have an ECC (Electronic Climate Control) issue, assuming thats what you have. I'm sorry, wish could be more help but that is way over my head.
96 850 Platinum Wagon
98 MB ML320
06 V70
95 850 GLT(RIP)
ArtyH
Post by ArtyH »
@ confused_al thanks for the reply info. Thought it would not be straight forward, looks like it need some cash thrown at the job, just my luck.
Thanks again for the reply.
andymoore
Year and Model: 2005
Post by andymoore »
I also have the same problem that happened at the same time in the Uk!!
I have a 2005 s60 T5 that now blows hot and cold every 3 secods with a pump sounding noise!!
Wonder if it is the extreme cold that has caused it?
Let me know if you get a resolve and I will do the same
