the surge
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
vovodad
Year and Model: 240/90
the surge
Post by vovodad »
hello everyone, I have the surge. while taking a trip in my 90/240 I stopped for gas. upon start my engine reved pretty high and continued to do this every time when started. I have notice when the car is shutoff for A while the surge is less. other than that when driving it's fine. :oops:
vovodad
Post by vovodad »
Hi guys I want to add some more info on the surge. I have also noticed that my temp gauge doesn't rise like it should to the correct range (only 1/4 rise) when at normal operating temp. Could it be that the sensor sends a constant cold signal to the ECU which causes a cold start on startup?
Reason: Reduced from all capitals in line with forum etiquette. All capitals equates to shouting.
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
I have moved this to the RWD section and altered your second post in line with forum etiquette.
If the temp gauge is reading low I would suggest that you need a new thermostat. On the B230 engines there are two temperature sensors. One supplies the temp gauge and the other feeds info to the ECU. If the thermostat is faulty the gauge will probably be showing the correct temperature. The coolant being under normal working temperature will have an adverse effect on the other temp sensor. The ECU will have bad info and adjust accordingly.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
