'99 S70 - Driving with a broken oil trap?
dongafish
Year and Model: S60, 2.5T - 2009
Post by dongafish »
I was moving some hoses/vacuum lines around looking for a disconnect and I snapped two plastic tubes/hoses (they were extremely brittle).
One is the size of a vacuum hose, the other is much larger (about 1/2" internal). I'm pretty sure they vent the oil trap back to the air intake accordion. Can I drive the car with these tube/hoses disconnected... just to get to the mechanic about 25 miles away? Or is it going to blow oil all over the engine?
2009 - S60, 2.5T - 69,000 miles
1999 - S70 - 215,000 miles
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
Not a good idea
FIX!
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 19 times
Post by jblackburn »
Duct tape! That'll keep it from blowing oil all over, then you can drive it there and get it fixed :mrgreen:
'98 S70 T5
2016 Chevy Cruze Premier
FCPEURO
Year and Model: 2006 XC90 V8
Post by FCPEURO »
+1
Don't drive it hard or anything, but you will be fine with a 25 mile trip to the mechanic.
dongafish
Post by dongafish »
If I duct tape it, what happens to the air that used to flow from the trap to the intake? Will it build up and damage something else?
If it won't damage anything else, could I just "close off" the oil trap?
larryh
Post by larryh »
if it's the hose i'm thinking it is....you might be able to splice it back together with a piece of rubber vaccum or fuel line hose. just find the size that the plastic hose will fit into. I've got about 70K on a repair just like it.
jblackburn
Don't close it off...that WILL build up pressure inside your engine and blow oil out the seals. I was suggesting to tape the big line back together, since it's not a high-pressure line, and you could do as larry said for the smaller one. I fixed a vacuum line on an older car for many years with a similar fix.
'98 S70 T5
dongafish
Post by dongafish »
Great idea.
I tried to splice them (larger and smaller one) back together with some temp resistant engine hose, but they're so brittle they just keep snapping like a pretzel.
So the final note is DO NOT close them off.
Thanks. What a great help.
renns
Year and Model: 2005 XC70
Has thanked: 3 times
Been thanked: 6 times
Post by renns »
The large line that runs along the front of the fuel rail, and down to the flame trap broke in half on my 850 non-turbo a while back. I drove for a few weeks with it broken. Other than the occasional whiff of hot oil smell in the cabin, there was no issue. There was no oil build-up under the hood. I suspect if the rest of your oil trap system is plugged, you may have problems doing as I did above, but it's worth a try. I've since patched mine up with a piece of 1/2" ID vinyl tubing.
The vacuum line you mentioned breaking may cause other issues depending on its purpose.
1994 850 5-speed wagon, retired at 400,000 km
1998 V70 AWD 5-speed, retired at 358,000 km.
2005 XC70 275,000 km - daily driver
