1990 240 Fuel Injector Connector Order
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
LA48340
Year and Model: 240 1988 & 1990
Post by LA48340 »
I am replacing the engine in my 1990 240 wagon. When I removed the intake manifold off the blown engine, I didnt number the fuel injector connectors 1 to 4. Not sure if this is critical to the firing order. I think I read they all get pulsed at the same time so order doesnt matter. Does anyone know if they are sequential and should be reconnected by cylinder order?
thanks.
LA48340
Post by LA48340 »
Did some investigation locally and found out the injectors are batch fired with connector order not critical. The factory does use a specific order when the car is built however. I connected them based on harness length and memory..the engine runs great. FYI.
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
Thank you for the update.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
