Any idea on what might be causing my radio to ramdonly change between FM1 FM2 FM3 AM and CD Player? How do I fix? Anyone else experienced this problem?
HELP
S60 Radio Issue - Changing between FM1 FM2 FM3 & AM
vegasjetskier
- Year and Model: 2010 Toyota Prius
- Been thanked: 6 times
Sounds like the mode switch is stuck.
vegasjetskier
Does your system have the rotary knob on the front to select the source?
vegasjetskier
You could try some adhesive, like a piece of Scotch tape, stick it to the button, then pull outward slightly and see if the problem stops. If it does, I'd go to a place like Radio Shack and get some Contact Cleaner or a Compressed Air Duster and carefully spray it into the side of the button or apply the hose from a vacuum cleaner over the button to see if that will solve the problem.
