Do I listen to the dealer about the tranny fluid?
Old Blue 66
- Year and Model: 2001 S60 2.4t
I was told it doesn't need to be changed at all. What do i do?
Paul
2001 S60 2.4t Owner 117,000 miles
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 19 times
Bullcrap. Jeep says the same thing, and the fluid in ours was BURNT. They just want your money when the transmission blows up. Either take it to another dealer, or find a good independent Euro mechanic that will do it for you, or do it yourself - it's really not hard, I promise.
Keep it far away from transmission flush machines - they are very very bad evil things.
If the transmission download has not been done on your car to deactivate the stop-neutral function, find someone that can do this as soon as possible. This in itself ends up killing most 2001 transmissions.
We have a write-up for the transmission flush method here.
https://www.matthewsvolvosite.com/forums ... php?t=8767
Your car will use the JWS-3309 fluid, not the Dex-III that S70's use, that you can buy from your dealer. Alternatively, the Mobil or Toyota fluids are acceptable if you can find them.
'98 S70 T5
2016 Chevy Cruze Premier
vegasjetskier
- Year and Model: 2010 Toyota Prius
- Been thanked: 6 times
On some of the newer models the manual says "lifetime" or "change at owner's request."cattledog wrote:What dealer would say that? Idiots!
Absolutely replace the fluid.
240's used to be on a 20k interval.
Your manual gives an interval, no?
billr99
- Year and Model: 2002 V70XC
Yep that's what they say. And they are still wrong if you consider "lifetime" to be anything over about 70K miles.vegasjetskier wrote:On some of the newer models the manual says "lifetime" or "change at owner's request."cattledog wrote:What dealer would say that? Idiots!
Cheers,
Bill
'05 XC70 (Lava Sand)-235K kms to-date
'02 V70XC (Ash Gray)-375K kms to-date
And a whole tonne of other Euro stuff (Volvo (8), VW (6), MB (1), Audi (3), BMW (2), SAAB (5), Land Rover (4), Porsche (2), Opel (1), MG (1), Mini (2), Sunbeam (1))
jblackburn
And here we see Ford's influence! That's about as long as most Ford's last before they start breaking downAnd they are still wrong if you consider "lifetime" to be anything over about 70K miles
'98 S70 T5
rbodor3
- Year and Model: 01 S60 LPT
- Been thanked: 2 times
ignore the dealer. "lifetime" means the lifetime of the warranty, it's a logistics/legal thing. Change the fluid.Old Blue 66 wrote:I was told it doesn't need to be changed at all. What do i do?
01 Volvo S60 2.4T
JRL
- Year and Model: Several
- Been thanked: 16 times
We DON'T see Ford's influence.jablackburn wrote:And here we see Ford's influence! That's about as long as most Ford's last before they start breaking downAnd they are still wrong if you consider "lifetime" to be anything over about 70K miles
This has been the same Volvo crap since 1994, "lifetime fluid".
CHANGE or flush (depending on your mileage) you transmission fluid or soon enough you WON'T HAVE A TRANSMISSION
polskamafia mjl
- Has thanked: 19 times
- Been thanked: 21 times
Simmer down, simmer down.
confused_al
- Year and Model: 1996 TLA wagon
People get upset when they talking about ATF issues...polskamafia mjl wrote:Simmer down, simmer down.
Well, this is what I know:
My 95 850 had first ATF changed (65k) at dealer as "recommended service";
My 06 V70's manual states ATF should be changed when "instrument panel display the msg". My interpenetration is "get ATF changed before see that msg".
M-B (Mercedes-Benz) was very proud about their "seal for life" trannys up to five years ago. At 50k mark on my ml320 I called M-B asked if I need an ATF change, the guy with the typical German attitude told me that their technology was so advanced that no ordinary rules could be applied. About 6-7 years into their usage (around 85k miles), these trannies (766.XXX) started to fail in a mass and owners were very upset. Two years ago, M-B officially changed their "seal for life" to replace ATF every 60k miles (more frequent if towing is involved).
I will replace my V70's ATF once I hit 60k, same mileage I did for my ml320, which still has silky shifting at 100k.
96 850 Platinum Wagon
98 MB ML320
06 V70
95 850 GLT(RIP)
98 MB ML320
06 V70
95 850 GLT(RIP)
- 1653 Views
Last post by ChrisatXeMODeX
- 617 Views
Last post by E Showell
