I've noticed that whenever I turn, I hear a rhythmic sound coming from the front end. More noticeable at higher speed. Can hear it a little going straight on the highway too.
I don't feel any vibration through the steering wheel.
Is this caused by the CV joints?
-os
Sound from Front End
1996 850 GLT 262k miles (gone
1999 Honda Civic (gone)
1996 850 GLT (gone, no more Volvos
2000 Buick Park Avenue (gone)
2005 Honda Odyssey (gone)
2013 Lexus ES350 (replaced Volvo 850)
2021 Honda Pilot
2021 Honda Pilot
- Year and Model: Many Volvos
- Been thanked: 75 times
The CV joints tend to clack more at low speed on a tight turn, what you describe sounds more to me like a hub bearing that is beginning to fail. Do you notice it more when turning one direction than the other direction?
I'll have to check that.Ozark Lee wrote:The CV joints tend to clack more at low speed on a tight turn, what you describe sounds more to me like a hub bearing that is beginning to fail. Do you notice it more when turning one direction than the other direction?
It does seem to be coming from the passenger side though.
-os
2021 Honda Pilot
2021 Honda Pilot
Definitely more when turning to the left.
-os
2021 Honda Pilot
2021 Honda Pilot
osmium wrote:Ozark Lee wrote:The CV joints tend to clack more at low speed on a tight turn, what you describe sounds more to me like a hub bearing that is beginning to fail. Do you notice it more when turning one direction than the other direction?
-os
If it is the bearing, do both sides have to be replaced?
Are Timken bearings good?
-os
2021 Honda Pilot
2021 Honda Pilot
Normally when wheel bearings fail the bad bearing is the bearing opposite the direction you are turning. In your case if the noise if more pronounced while turning left it is the right hand bearing at fault.
I think FAG are the OEM hub suppliers but I have no experience with the Timken brand, they may be fine or they may be junk. I bought some cheap Chinese hubs off of eBay for a Jeep that we had and they lasted all of 6 months.
Ozark Lee wrote:Normally when wheel bearings fail the bad bearing is the bearing opposite the direction you are turning. In your case if the noise if more pronounced while turning left it is the right hand bearing at fault.
Ok, thanks.
I'm going to have a crack at replacing it.
Two questions:
Do I have to replace both sides or just the side that's bad?
Will I need to get an alignment when done replacing the hub?
-os
2021 Honda Pilot
2021 Honda Pilot
When I have dealt with hubs I have done them in pairs but it may not be necessary. In my case I did not need to get the car aligned again but let your steering wheel be your guide. If the center position changes on the steering wheel then get it aligned.
The sound is now occurring whichever direction I turn. It's still coming from the passenger side but I can feel it more. The car is now on the IR.Ozark Lee wrote:Normally when wheel bearings fail the bad bearing is the bearing opposite the direction you are turning. In your case if the noise if more pronounced while turning left it is the right hand bearing at fault.
With the change in the sound, is the wheel bearing still the suspect?
I took the tire off and looked around. There doesn't seem to be anything obviously wrong. The CV boots are ok. Nothing else was lossed/broken. Put the tires back on and did the 12-6 and 9-3 test. No movement. Spun the wheel but no sound.
Also noticed the axle nut is pretty rusted (lotta salt on the roads here in NH). Put some penetrating oil on it. But that bolt worries me.
-os
2021 Honda Pilot
2021 Honda Pilot
