Suspension Hoes...er i mean Woes
i hate my volvo
- Year and Model: 2000 v70xc
sorry for any redundancy. my car has the common ambiguous ''clunk'' coming from the right front corner. i've come to the conclusion that it is probably the strut mounts, spring seats, sway bar link, control arm/ball joints and/or sway bar end/drop link (really narrows it down). it has progressively gotten worse for the last 6 months. when i first heard the noise it would only happen at low speed over bumps i.e. parking lots, dirt roads. when on dirt roads the steering wheel wont bounce around in my hands, but i can feel something loose, jerky or playful sending feedback through the wheel suggestive of a worn steering rack or tie rod? i took the car to les schwab which was my first mistake; but i was busy and they were close. they replaced a tie rod end that they said was worn. now i look under the car and find the boot on one of the tie rod ends to be completely torn. i'm sure the magnificently qualified technician at les schwab didn't miss that, so it must've completely deteriorated in 5 months time
. the rubber piece on top of the strut was also replaced when i bought the car -- this is a common failure point, correct? however legitimate the russian gentleman i bought my car from may have been, he was a wholesale dealer and there is a stereotypical stigma surrounding the situation. so, before wasting anymore time and money and risking high speed failure, i want to fix the problem. i am mechanically inclined as far as installing or replacing parts but i suck at diagnosing anything but a vw bug. so i figured on this package put together by fcpgroton.com for a little under $500 . they claim "It will eliminate any vibration/ shimmy/ clunking/ rattling that you may be experiencing" . i am wary of the quality of most aftermarket parts. is URO a reputable company, or will it fall apart in 6 months. here is the link: http://www.fcpgroton.com/product-exec/p ... ory_id/181 also they have a rebuilt steering rack for under $300, is that a deal? thank you all, i am eternally grateful for any input.
I would say it's either your drop links or your anti roll bar bushes. My UK Spec had the same problem replaced both drop links along with both anti roll bar bushes now the noise has gone.
855 T-5 RHD Blue: MBC, Custom Map based on Rica, K&N Filter, 18T Turbocharger, White/Green injectors [depends on my mood], Blue Silicone vacuum hoses
That's a great deal on those parts.
Upper strut mounts, pop the plastic caps off the top of the strut under the hood at the strut tower. Use a wrench and see if you can rotate the nut, if it rotates with no problem the upper strut mount is broken. If on the other hand it moves alittle but you feel springy resistance, and it wants to return to where you started, it not broken....yet. You can use XC90 upper strut mounts, they're slightly heavier duty.
polskamafia mjl
- Has thanked: 19 times
- Been thanked: 21 times
Stay away from URO!!!!! lol They can't make radiator hoses I doubt they can make quality suspension parts.
i hate my volvo
that's all i needed to hear. i figured if the price sounded too cheap to be true it was. i'll try the above stated parts as well as the obvious torn tie rod end boot. thanks guys. any other suggestions would be appreciated
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
+1 on the XC90 spring mounts. Just try to twist it with your hand...if it spins right around, it's bad. If it turns a little bit, do the bounce test with the fender of the car.
Upper shock mounts rarely go bad. But it does happen. Sway bar endlinks will give you a lot of clunking too.
If you replace them, you'll need to rent a spring compressor. Make sure you have an alignment done afterwards, or your tires will wear out awfully quick.
'98 S70 T5
2016 Chevy Cruze Premier
polskamafia mjl
cattledog wrote:i hate my volvo....what's up with your name?
I love my Volvo.
i hate my volvo
which year xc90 mounts? i think i'm replacing upper spring mounts, sway bar endlinks inner and outer tie rod, probably struts and rebuilt steer rack soon. i'm nervous...why do i always get the maintenance nightmares. what aftermarket manufacturer IS known for their quality? what about meyle?jablackburn wrote:+1 on the XC90 spring mounts. Just try to twist it with your hand...if it spins right around, it's bad. If it turns a little bit, do the bounce test with the fender of the car.
i hate my volvo
let's trade for your v70rcattledog wrote:i hate my volvo....what's up with your name?
that is a lot considering i've owned the car less than a year. i've fixed everything except the door panels and now the suspension and i could've bought a parts car for cheaper. i understand my plight is unlikely to be typical, it has been a bad first experience. but i'm hanging in there thanks to many helpful people such as yourself. thanks again.
- 1800 Views
Last post by aaronlife
- 2937 Views
- 12 Replies
- 3437 Views
Last post by metalslug
- 1017 Views
Last post by mrbrian200
- 738 Views
Last post by oragex
