nauseating odor
addiligence1
- Year and Model: 2002
nauseating odor
My 2002 S40 has a horrible chemical odor eminating from the heating vents while the car is being driven. I have to drive with the windos open. Help! What is this?
addiligence1
Discovered car has cabin filter. when removed it appeared the coolant has been leaking through the heating vents onto the passenger side floor. (That was the odor). Coolant level was greatly depleted. But we can't seem to find where it is specifically leaking. Any thoughts?
addiligence1
Definitely coolant. We think the heater hose may be leaking.
Does anyone know how to get to that?
dtropnevad05
- Year and Model: S-80, 2001
Here in the States Anti-Freeze is often called Coolant.nifton wrote:that's a bit odd, can't think how coolant has got up there, you sure it's not anti-freeze? I can see how that might seep through from the wiper feeds if there's a split hose near the air heater.
I think by "coolant" you are thinking he is talking about Freon that is used in the AC system?
The other thing you might have going on is a leaking heater core unless you have already confirmed the heater hose.
addiligence1
The transmission light just came on while driving to the store. Is this related? What does it mean? Manual is no help.
Transmittion light is actually flashing.
dtropnevad05
First thing I would do is check the fluid level and make sure it is where it needs to be. If you coolant is low the trans might be over heating and that is not a good thing. You should not drive the car until you fill the coolant/anti-freeze to the proper level!
addiligence1
Thank you. We will do that right now.
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 19 times
Your heater core has probably developed a crack. It is a common issue with the 850/-70 series cars, and a very easy fix on those. I'm not sure where it is on the S40, but if your footwell is damp, chances are there is an access panel to change it out in the center console.
http://volvospeed.com/vs_forum/index.ph ... re-install
'98 S70 T5
2016 Chevy Cruze Premier
addiligence1
Thank you. Can you give me a bit more info on this?
