Jack point for lifting front of '01 V70?
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
bocephus
Year and Model: V70 T5, 2001
Post by bocephus »
So I've searched through the forums (both here and at Swedespeed), but I can't seem to find any conclusive (or particularly helpful) information regarding where on the front end to position a hydraulic floor jack. I'm using a 3-ton jack, and I'd like to just slide it in under the car from the front and lift both front wheels off the ground. The Volvo manual doesn't offer any advice here; behind the radiator there's a subframe beam with an indented circle, surrounded by four indented lines--is this a "designated" jack point?
Sorry for asking such a newb question, but I really don't want to mess anything up in the process of trying to make repairs.
850 Turbo1
Year and Model: 1996 Volvo 850
Post by 850 Turbo1 »
I'm not totally sure if it's a 'designated' jacking point...but I have used it over 10 times..no issue there!
Good Luck!
oh and to correct your spelling mistake...you meant 'noob'...lol... :lol: :D
1996 850 T5 Sedan
1996 850 T5 Platinum Edition Wagon
--Always Learning--MB--
confused_al
Year and Model: 1996 TLA wagon
Post by confused_al »
For all the 850s:
http://volvospeed.com/Repair/jackingpoints.php
I use a piece of 2x4 put under the sub-frame cross beam and jack up from that (on my both 850 and v70), works well for me.
96 850 Platinum Wagon
98 MB ML320
06 V70
95 850 GLT(RIP)
JDS60R
Been thanked: 3 times
Post by JDS60R »
Please open the PDF and see page 177 of 243 for lifting instruction. It was not designed to be lifted with both front wheels at once but you can jack from one side and put a jack stand under the lifting point. Then do the same ont he other side.
The subframe is too soft to jack on it. I have had to replace a few.
v70_2001 owners manual.pdf
(3.31 MiB) Downloaded 2275 times
Retired
850 Turbo1
850 Turbo1 wrote:I'm not totally sure if it's a 'designated' jacking point...but I have used it over 10 times..no issue there!
Good Luck!
Come to think of it...I realize my advice my have been a little foolish...just because it worked 10 times doesn't mean it is the right way to do it. Sorry I was a bit tired last night. I agree with JDS60R that jacking the whole front end from one spot is not a good idea.
Cheers!
1996 850 T5 Sedan
bocephus
Post by bocephus »
Hmm...on page 177, the manual states that "A garage jack can also be placed under the front of the engine support frame," though it also specifies that "If a garage jack is used to lift the car, the two jack attachments points should be used." Confusing, to say the least, which is why I posted my question here. But, if the general consensus is that jacking the front end from one spot is not a good idea, then I'll just go ahead and jack from the sides.
Thanks!
JDS60R
Post by JDS60R »
Hi 850 Turbo 1
Great to see you - hope all is well.
I like your idea. By displacing it across the width of the subframe you should be fine. As an appraiser I have had some folks jack it up from the front "as the manual says" but the contact point from the jack to the fram was only 1.5 to 2 inches wide.
I have seen this bend the frame. I think if you place the load across the front member, as you described ,and then put the jack points on jack stands you would be fine. To displace it you would need a good strong piece of wood or metal.
I would love to have a jack that could lift both jacking points at one time. That would be Awesome. Someone could fabricate a plat that went across and locked into the jacking points and then you could jack on that in the middle. If somebody out there has one please let me know.
Retired
Checksix
Year and Model: V70 T5 2001
Been thanked: 2 times
Post by Checksix »
I've done every oil change and more with 105K miles jacking up the car from the center of the cross beam using a simple floor jack with no other things like 2X4's. Guess my wheels fill soon fall off! Anyhow, so far I'm glad to report no indications of an issue like poorly wearing tires. Having a nice shaped adaptor to distribute the force would be nice, but it would need to be relatively stiff, and I'm not sure how to get there, but I guess anything would be better that what I'm doing, Ha Ha!!!
Jacking side to side would induce a lot of stress on the bushings on the side on the ground if one goes this route. Not sure which is worse.
Jerry
01 V70 T5a 175K miles on 3/2016
73 P1800ES 370K miles (RIP)
73 145 about 320K mile (gone with the "X" long ago)
59 Austin Healey Bugeye 2000cc Hemi 150HP
69 F100 (original owner) This truck will RUN FOREVER! (Sold for 2008 F250 diesel in 2013)
