2000 V70 Fuel Filter
banjones98
- Year and Model: V70 2000
Hi, I just spent a good while trying to figure out how to change it and I'm baffled. Any tips on this. I'm a newbie and sure would appreciate it.
JDS60R
- Been thanked: 3 times
Not every car has one other than the filter sock on the in tank pump
Most do.
You will have to pinch and pull the lines on the tabs next to the filter or some have a clip that you remove (usually white or clear plastic) and then the line slips out.
Here you go.
Most do.
Here you go.
2000 V70 fuel filter change.pdf- (49.08 KiB) Downloaded 228 times
Retired
