97 T-5 CD Kicking at higher speeds boost 3/4
charlyW
Year and Model: 97 855 T-5 CD
Post by charlyW »
Had to take my T-5 for good drive today to collect some parts [oops slide into a post] now the car is kicking at 60-70mph only when boost needle goes around 3/4 also Lambda light has come on. Slower speeds the car is fine ok the accelerator pedal is incredibly stiff any suggestions ?
I'm going to have a look over the weekend along with fitting a new PCV [dreaded oil is coming out of filler cap]
855 T-5 RHD Blue: MBC, Custom Map based on Rica, K&N Filter, 18T Turbocharger, White/Green injectors [depends on my mood], Blue Silicone vacuum hoses
charlyW
Post by charlyW »
It has been suggested to be one of three main areas causing this kind of fault
1: spark plugs are past it
2: Vacuum leak on the actuator
3: Speed or RPM Sensor [coincedentally my speedo has stopped working]
A better explanation of the fault its more like the car is stopping the fuel pump any futher suggestions greatly appreciated
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 19 times
Post by jblackburn »
It sounds like the ECU's cutting out the fuel flow. It could be a wastegate actuator is allowing it to over-boost, and the ECU in return is like "hey! no! don't do that!" I doubt it is the RPM sensor if you're not stumbling at other rpms, and the speedometer on a 97 is controlled by the ABS module.
Could also be a vacuum leak at one of the turbo lines.
Does it do the same thing in 1st gear at higher revs, or only around 60 in 2nd?
The best thing to do would be to get the codes pulled :mrgreen:
'98 S70 T5
2016 Chevy Cruze Premier
charlyW
Post by charlyW »
jablackburn wrote:It sounds like the ECU's cutting out the fuel flow. It could be a wastegate actuator is allowing it to over-boost, and the ECU in return is like "hey! no! don't do that!" I doubt it is the RPM sensor if you're not stumbling at other rpms, and the speedometer on a 97 is controlled by the ABS module.
It's only around 60 mph it happens never in lower gears. This morning "Sport" mode has stopped working with not speedo, RPM is fine. [finally a good point to satnav]
jblackburn
I bet it's the yellow vacuum line to the turbo control valve. The wastegate is supposed to relieve excess pressure to keep you from overboosting, but it can't do that if the line that opens it is cracked. Therefore, the ECU's compensating and cutting back on the fuel. Have a look-see at the lines there.
The speedo is probably either a wheel sensor out of whack or the ABS module up and died. You don't have any lights? I guess that makes GPS good for something :shock:
As a map maker, I hate the darn things. I have a decently nice model, and it's still a complete idiot, trying to take me up unpaved gravel or crummy secondary roads whenever it has the chance.
Have you seen this for R&R'ing the ABS module yourself?
https://www.matthewsvolvosite.com/forums ... hp?p=46827
'98 S70 T5
charlyW
Post by charlyW »
jablackburn wrote:I bet it's the yellow vacuum line to the turbo control valve. The wastegate is supposed to relieve excess pressure to keep you from overboosting, but it can't do that if the line that opens it is cracked. Therefore, the ECU's compensating and cutting back on the fuel. Have a look-see at the lines there.
It is the yellow one and the blue and the other one, cant say what colour that was its missing. Yellow one is connected to nothing its crumbly, blue one connected to nothing just sitting on the airbox hose doing nothing, other one gone I know theres supposed to be a third because theres a tiny bit left on the actuator. Hole in the Intercooler pipe.
All pipes on order from local volvo main agent [main stealer as I call them because of the prices £10.50 a metre of 4mm vacuum hose]
jblackburn
I'm kinda surprised it's boosting at all then!
Here's a diagram for you when you get em all fixed up:
'98 S70 T5
charlyW
Post by charlyW »
jablackburn wrote:I'm kinda surprised it's boosting at all then!
Thanks that will help no end and shows whats missing and where the new pipe work should go.
Charlotte
charlyW
Post by charlyW »
Here is an actual picture of the coloured vacuum hoses
Turbo Vacuum pipe colours.JPG (21.45 KiB) Viewed 1803 times
skidaddy13
Year and Model: S70 GLT 1998
Post by skidaddy13 »
charlyW wrote:Here is an actual picture of the coloured vacuum hoses
having the same issue i think, does anyone have a better photo and instructions?
