Hi
Can anyone help? I have a heavy clunk when I pull away in my 2001 Petrol 2 wheel drive S60. It has done 70K and I have recently replaced the suspension tops (both rubber bushes were shot) and I have also replaced the top engine mount but I still have the clunk when pulling off, the faster I pull away the harder the clunk.
When I changed the top engine mount I noticed that the cross bar that it mounts to swivels quite a lot at both ends where it connects to the inner wings, is this normal? or do the crossbar bushes need replacing.
Thanks for your help
Frank
S60 Clunk on take off.
Rear Wheel Bearing Replacement
wolfspiritky
- Year and Model:
Does it also do it on slightly hard or hard breaking?
May need to install O-ring kit to the sub-frame mounts.
This solved the "Clunking" issue I had (on take off and breaking) on my 2000 S80 T6.
00 S80 T6
97 850R
94 850 GLT-Totaled!
97 850R
94 850 GLT-Totaled!
537playing
- Year and Model: 2005 S60
- Has thanked: 1 time
- Been thanked: 5 times
How about inner and outer tie rods?
Frank Brennan
- Year and Model: s60 2001
Thanks for all the advice, I will investigate and let you know what I find.
Frank
Frank
Joe Hurless
- Year and Model: e36 328is
I just saw something like this the other day. What happened was the lower right engine mount below the timing cover was toast and, due to it being torn out, had put extra strain on the upper engine mount (which totally ruined it). The engine was literally jumping out of the car. So my advice would be to get the car on a lift and inspect all of your engine mounts.
JRL
- Year and Model: Several
- Been thanked: 16 times
That would be the FRONT engine mount (right side of the car)
Does your transmission have the latest software?
You could be running the dreaded original software with the stop neutral feature still enabled.
If so, GET THE LATEST TRANSMISSION SOFTWARE ASAP or you will destroy your transmission (if it hasn't been already)
Joe Hurless
Wow... ok. It seems I must apologize for my lack of perfect terminology...JRL wrote:That would be the FRONT engine mount (right side of the car)
In any case, the mount in question is below the serp belt and timing cover on the right side frame. Often, Seal leaks, water pump leaks, and power steering leaks can cause this mount to become punky and break. I would put the car on a lift and use a jack to lift the engine and see if it separates from the mount.
- 1049 Views
Last post by Volvo S80
- 1274 Views
Last post by peacelover60
- 15 Replies
- 3062 Views
Last post by erikv11
- 1040 Views
Last post by Oka
- 19 Replies
- 1942 Views
Last post by matthew1
