My V70 has been experiencing a front wheel shimmy at different speeds, but mostly noticeable when traveling on the highway. The problem has been getting worst over time and it was finally time to do something about it before I would do some serious damage to the car.
I first had the tires balanced, but realized quickly that the issue was not resolved. After conducting some research I next placed the blame at the outer tie-rods and this is my write-up for replacing them. Tie-rods wear out with time at the ball joints and therefore become loose causing the front wheels to shimmy. Please be advised that I am by no means a professional mechanic, but follow directions from manuals and websites like this one.
I called the next closest dealership in Lexington, KY and got a quote of $350 for replacing the outer tie rods for both sides. Next I got a quote from a Volvo shop in Louisville that replaced my timing belt last year; once again the number was close to $300. Next I did some reading upon the subject and FCP Groton had both the LH and RH for a total of $39.90; I ordered them on Friday and the UPS truck showed up today, Tuesday morning.
Here are most of the parts…tools, hydraulic jack, jack stands and 2 new tie roads (fake Persian carpet not necessary)…
First loosen those lugs…
Then jack the car up at its appropriate places and place some jack stands under some strategic points to catch the vehicle in case the hydraulic jack fails…
…and one in the front…
…make sure to secure the rest of the vehicle…
For this task I was armed with Matthews Volvo…
…and this great manual…
…the secured job site without the wheel…
…here is the culprit…
…a side view of the tie-rod…
…a closer inspection of both ends of the tie-rod…
…and the joint that wears out and the reason for replacement in the first place…
…for all I know, the tie-rods on my vehicle have never been replaced, therefore the connections were extremely rusted and I needed the help of some PB Blaster; great stuff…
…In order to loosen the nut on-top of the tie rod ball joint one needs to use two wrenches; one to keep the ball joint from turning and the other to undo the nut. As mention before, the PB Blaster makes this task much easier…
…once the nut is undone the tie rod ball joint drops right out…
…next comes a very important step; it is vital to remember how far the tie rod was screwed into the inner tie rod and therefore when loosening the nut on the inside end of the outer tie rod, make sure to just turn it one revolution out; when placing the new tie rod back into place, you will have an estimated position on how far to screw it in; in this picture I used a wrench to undo the nut and turned it ONE revolution out, a slight gap can be seen (on top of the black end of the outer tie rod)…
…in order to undo the outer tie rod (once again rust has settled in for the past years) one has to use two wrenches; the first to keep the inner tie rod from turning and the other to get the outer tie-rod undone. Once it starts turning count the revolutions it takes to undo the outer from the inner (23 revolutions in my case)…
…and VOILA, the old tie-rod is out…
…great comparison between a used old worn outer tie-rod and a new one…
…here is the new equipment…
…I first turned the new one in (23 revolutions), then attached the ball joint back into place and tightened all the nuts back into place…
…and the wheel back in place…
After double checking all the nuts, bolts and connections, I took the car for a test drive and much of the vibration was eliminated, but I decided to replace outer tie rod number 2 as well; here it is after installation…
Once again test drive and although I was very careful making sure I placed the tie rods back into place the way I removed them, the steering wheel was just not right turned to the left slightly in order to keep the car straight, which is an obvious indication that the front wheels are not aligned correctly. But the main concern I had was the wheel shimmy and after replacing both outer tie-rods, everything is extremely smooth. Tomorrows task is to align the front wheels with the help of this great write-up…
https://www.matthewsvolvosite.com/forums ... 54&start=0
I will conclude my write up upon completion of the alignment…
In conclusion for today I can attest that once again by doing a little research one can save lots of money by fixing the problem of front wheel shimmy yourself. The task in replacing both units took me about 1 hour. With the help of the Haynes manual and this website I was able to get rid of an annoyance and a potential future serious problem. This replacement is certainly not very difficult in nature and anybody who is handy with tools can accomplish what I did today. In addition the price of the two tie-rods compared to have a shop do the job, one saves somewhere close to $250.
As with my previous posts, if there are any suggestions on how I could have done this better or possibly I missed something, please let me know.
Back tomorrow with the alignment results.
Jan
