Thanks for all the detailed info on this forum. I've read into a number of the issues/annoyances that I've found with the '96 850R wagon that I am considering purchasing.
I still have some questions though:
1) None of the cabin/dome lights work. The rear passenger dome lights don't work either. Is this a bulb, fuse or wiring thing? Also, this car has the sunroof problem where it won't close all the way unless you give it some "help." Is that related?
2) The black pillar trim is cracking off exposing what I guess is aluminum underneath. Is this gonna be problematic with rust and things underneath the aluminum and in the pillar itself? (Ok I know this might be nit picky)
3) Timing belt - Does the mileage number on the cover indicate the mileage it was last changed or when it should be changed? I'll get a for sure answer on this when I pull maintenance records, but I am anxious to know.
The rest of the stuff I was looking for I already found.
Thanks!
-Jay
