turbocharger pressure map
How to go faster, stop quicker, and turn harder. Chips, exhaust, larger turbos, bigger/slotted/drilled rotors, high performance brake pads, manual boost controllers, performance shocks/struts/springs, airbox mods and more! Also discussion on HID and Xenon lights, aftermarket foglights and other exterior lighting.
This topic is in the MVS Volvo Repair Database » MSD Ignition Coil Install Photos
charlyW
Year and Model: 97 855 T-5 CD
Post by charlyW »
Can someone translate this please and advise which will be the best alternative Turbo as an upgrade to the 15G until I can get a manifold to fit the 18T
855 T-5 RHD Blue: MBC, Custom Map based on Rica, K&N Filter, 18T Turbocharger, White/Green injectors [depends on my mood], Blue Silicone vacuum hoses
