OBD II Code P2402
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
This topic is in the MVS Volvo Repair Database » Ball Joint / Control Arm Survey
Seatle S60
Year and Model: 2004
OBD II Code P2402
Post by Seatle S60 »
2004 Volvo S60 -
Is there a common culprit for this fault?
Dan
Seatle S60
P2402 - Evaporative Emission System Leak Detection Pump Control Circuit High
Anyone?
jda2000
Year and Model: 04 V70 2.5T 01 V70T5
Post by jda2000 »
a bad fuel cap and charcoal canister hoses leaks can give you evaporative system leaks.
If the car is running fine, clear the code and make sure fuel cap is tight. See if the same code returns.
