How to remove/replace sunroof?
Entire sunroof system replacement
wheelsup
- Year and Model:
- Has thanked: 16 times
- Been thanked: 22 times
Is there a walk thru that explains how to remove and/or replace the sunroof in its entirety? My parts car is being towed tomorrow and I wanted to get the sunroof out of it before it goes.
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
If all you want is the glass, it's easy. Pull away the plastic molding, and there are 4 screws holding it in on each side. The push up and back on it and it'll lift right out.
'98 S70 T5
2016 Chevy Cruze Premier
wheelsup
- Year and Model:
Ok found Ozark's writeup about gluing the material one, wondering if I can take apart the entire thing or just the glass? The sunroof on the parts car is in really good condition but mine is slightly rusted. I wanted to replace the entire thing, gears/motor included if possible?
https://www.matthewsvolvosite.com/forums ... 0393#30393
wheelsup
- Year and Model:
Just saw your post. Yep, the glass replacement looks straight forward. I will definitely do that. Is the mechanism a PITA to get out?
jblackburn
Now that, I've never done, but it doesn't look too hard either.
Take out the screws for the overhead panel, pry out the lights, and the motor's right there. Supposedly there just 3 screws hold the motor in, but like anything else with one of these, I suspect it's more complicated than that.
'98 S70 T5
wheelsup
- Year and Model:
I'll have to look at it tomorrow, I was thinking there were some tracks and stuff that it rides on/in. I think mine have gone bad because it takes a god aweful long time for it to slide backward.
I hope I can just hook the battery cables up to the battery and the sunroof will work too, the engine is out of the car so I don't know how the wiring harness works with hooking into the rest of the car.
wheelsup
- Year and Model:
Well I swapped the sunroof and the trim panel inside. Went pretty easy. Found out the reason mine pulls slowly backward is because it needs a little grease on the rails it seems. I'll try adding some and see if that helps. The donor car sunroof had zero rust and looks good. Glad I was able to swap it over, using Lee's writeup made it painless.
whoa
- Year and Model: 850 Turbo Wagon 1996
Do the sleds come out of the rails somehow so that one could be replaced? One of my sleds broke off at the rear where it screws onto that metal tray-ish cross-piece that the rear of the glass sits in (or apparently is supposed to sit it---the cross-piece was rattling around loose in my car).
1996 850 Turbo Wagon
wheelsup
- Year and Model:
Not sure I quite under stand what your question is. The parts car was towed away today but I left my cars sunroof off to clean it properly. I'll snap some pics for you tomorrow and post them up.
By sleds do you mean the part that moves or that is fixed to the car?
- 7102 Views
Last post by SuperHerman
- 924 Views
Last post by 122sPhil
- 967 Views
Last post by a061469
- 2098 Views
Last post by erikv11
- 6833 Views
Last post by badbigdad
