98 S70 Antenna Removal
sgowda2011
- Year and Model: S70, 1998
Hi, it seems that my antenna is broken when i power on my radio i hear a sound that my antenna is going up but it does not, the same happens when i turn it off. I am not sure if its completely broken or just the mast that seems to not work. Are there any steps i can follow to remove the antenna and replace it with a new one or perhaps just the mast. Thanks
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
Most likely just the mast - I stripped mine out during the winter because I was too lazy to clear the snow off the back of my car. Then I bent it in a car wash.
There's a nut at the top of the boot where it pops out of the trunk - loosen that, pull out the old mast. Take note of the direction the toothy strip faces. Now feed in the strip for the new one while you have someone else turn off the power for the radio to run the motor, and hopefully it will catch in a few tries and suck it right in.
Very easy fix, I ordered my replacement mast from FCP Groton.
'98 S70 T5
2016 Chevy Cruze Premier
1. open the trunk and use a fat screw driver to take off some of the liner clips on the driver side of the trunk. with this peeled back you can see the whole antenna assembly.
2. with the antenna pushed down take a crescent wrench to the out side portion of the antenna and loosen it up so that it can some down through the bottom.
3. there should be one or two bolts holding in the power antenna assembly and it should have a wire relay attached to it. remove those and remove the antenna assembly.
From here u can replace the whole thing or just buy a new mast.
1998 S70 T5 SE 214,001
1999 v70R 126,000
1999 v70R 126,000
sgowda2011
After removing the whole assembly how would i take out the old mast.
jblackburn
If the motor still runs OK, you don't need to take off the trunk thing or get at the motor.
Just remove this nut and pull the old mast out, then feed in the new one
'98 S70 T5
sgowda2011
The motor runs okay i guess, but its the mast thats the problem it wont come out and therefore i cant pull it out and replace it with another one. If i open up the trunk will i be able to access the old mast, or is there another way to get at the old mast.
jblackburn
Ohhh, gotcha.
Get to the access panel like peacock said, and push the mast up slightly, then you can pull it straight out.
'98 S70 T5
sgowda2011
Okay, I should access the trunk and remove the assembly and then i will be able to remove the mast right.
sgowda2011
Allright, I have removed the antenna assembly but i am now confused as to how to remove the old mast. Are there any specific steps i should follow to remove the mast. Thanks
- 3062 Views
Last post by mika
- 4830 Views
Last post by aradoarado
- 1729 Views
Last post by doogandougie
- 12 Replies
- 2570 Views
- 323 Views
Last post by vicknightingale
