Control Arm and Ball Joint
pman7373
Year and Model: s70 GLT SE 2000
Post by pman7373 »
Hi,
I was wondering how you can tell when the control arm or ball joint are starting to fail?
Also what is involved in fixing it yourself.
Thanks!
2000 S70 GLT SE Turbo 109,000 miles
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 19 times
Post by jblackburn »
Most of the time, you can tell by floaty, loose steering that darts around in hard acceleration and it seems like your car can't stay in straight line.
If you want to check them, jack up your front wheels and try to shake the wheel up and down or side-to-side. There should be no play in any of your suspension components by hand.
They are not terribly hard to replace yourself - the hardest part is just getting the rusty bolts free. Keep in mind that after you change any suspension or steering component, you will need to have an alignment done.
'98 S70 T5
2016 Chevy Cruze Premier
pman7373
Post by pman7373 »
Thank you for the help! I am going to jack my car tomorrow. Hopefully they're fine!
polskamafia mjl
Has thanked: 19 times
Been thanked: 21 times
Post by polskamafia mjl »
If you are upwards of 100K miles chances are they need to be replaced.
