Starts when jumped only
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 19 times
Re: Starts when jumped only
Post by jblackburn »
If you've got your own voltmeter, try a parasitic drain test - this is for a 240, but should help you out a lot:
https://www.matthewsvolvosite.com/forums ... =2&t=26627
What voltage is the battery at before you jump it? I have seen batteries with problems holding a charge under LOAD due to bad cells.
'98 S70 T5
2016 Chevy Cruze Premier
charlyW
Year and Model: 97 855 T-5 CD
Post by charlyW »
Check the body to battery and engine to body earths along with the tailgate switch either may be your problem
I'd opt for an earth fault
855 T-5 RHD Blue: MBC, Custom Map based on Rica, K&N Filter, 18T Turbocharger, White/Green injectors [depends on my mood], Blue Silicone vacuum hoses
charlyW
Post by charlyW »
Tailgate switch or you call it a trunk switch it turns the boot light on or off it might be jammed on
Trenchcoat
Year and Model: 850, 1996
Post by Trenchcoat »
Make sure the posts contact the terminals properly. I've had the same symptoms as you've listed. Make sure to use a voltmeter to check the connecting clamps themselves instead of the battery posts.
