Volvo 240 rear brake light
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
Guest
Post by Guest »
One side of my brake lights do not work. The bulb is not the problem. Neither is the bulb holder. What should I look into next? Thanks.
40 years in volvos
Post by 40 years in volvos »
Check to make sure that the bulb holder electric tabs and their connections to the printed circuit are clean. Next check the ground from the printed circuit to the car body.
Guest
Post by Guest »
40 years in volvos wrote:Check to make sure that the bulb holder electric tabs and their connections to the printed circuit are clean. Next check the ground from the printed circuit to the car body.
Sorry to hijack the post....both of my brake lights are not working but all taillights are. I've checked all the obvious (fuse, bulbs and brake switch) that I can think of, still no luck. Anyone know what else should I check? TIA
SMerrill8
Post by SMerrill8 »
I found that the plastic parts were failing and it introduced rainwater into the bulb area, which continually fried the bulb.
Bobby Joyner
Year and Model: 1986 240 dl sedan
Post by Bobby Joyner »
I had the same problen on my 1986 volvo 240 dl & the contact that plug into the printed circuit board were coroded & dirty.
Used CRC electronic cleaner on the plug & receptical & now all is well. Bobby Joyner
