I have an audible air/vacuum leak sound when depressing the brake pedal. Braking is somewhat delayed until I press the pedal more, then braking is better. I can find no reference to this booster part availability. What is the situation here??
Thanks
'96 960 vacuum brake booster
There's a check valve that has a vacuum line running into the booster. Most of the time from what I understand, the valve can let go and cause problems like this. In my case however, the booster (or brake servo it could be called) has an actual leak and I'll need to replace it eventually. You're better off paying the 30$ for a boneyard part or find a remanufactured unit, because new from Volvo when I checked they were extraordinarily expensive!
Remember that if you put in a new valve or take yours out to test it to put some vasoline or something on the rubber so you don't tear it
Let us know your findings,
Darrell
Darrell
After the engine is stopped, and I first press the brake pedal the hissing sound occurs only briefly . Does this mean that the check valve is OK and that the booster itself is leaking internally?
Thanks
Thanks
Sorry I didn't see your response earlier! I actually did check with Volvo out of curiosity and a) my dealership doesn't stock the servo for the 700 series, b) if I remember correctly they wanted $700+ for that unit. Glad you were able to find one for not too much dough! How did you determine that the diaphragm was leaking?
Darrell
Darrell
- 936 Views
Last post by EstVolvo
- 2632 Views
Last post by DraftyBread
- 952 Views
Last post by volvo2006taj
- 4487 Views
- 982 Views
Last post by sleddriver
