I bought an 850R 30 days ago with 180k on it. Nearly on a daily basis, fuse 15 blows and the door chime won't stop. It comes on when you put the key in - not even started - and stays on. The interior lights don't work either. If I replace the fuse, it's ok for a day or two then blows again. (I knew the car had this problem but it is in near showroom condition in and out so I bought it)
A couple times when I went to change the fuse, the fuse blew as I out it in so there was a dead short somewhere at times.
I have read about removing the door chime module but that would leave me with no interior lights. I guess I could live with that but I would like to fix it right. At one point when the fuse was blown, I dis connected the harness as it goes into the door - that round twist ring, and nothing changed.
Also - the other day a strange whine kind of electricalish high pitched and intermittent started coming from under the dash. Any idea on that?
Thanks all,
Jim
97 850R door chime won't stop - blows fuse 15 daily!
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 19 times
Removing the door chime relay won't disable your interior lights. The seatbelt reminder lights won't work anymore, but that's it.
The central lighting relay is a different relay altogether.
It sounds like either the microswitch in your door is broke, or there is another short in the system. I would try removing the door chime relay for now, replace the fuse, and see if it still blows. Then try removing the big K relay on the 3rd row up if it doesn't work.
'98 S70 T5
2016 Chevy Cruze Premier
jblackburn
That's your central lighting relay.
'98 S70 T5
- Year and Model: Many Volvos
- Been thanked: 75 times
Have you done anything with your sun-visors lately? As I recall the lights for the vanity mirrors run off of the same circuit and that could be the root of the problem.
- 509 Views
Last post by RickHaleParker
- 8372 Views
Last post by dcm0123
