thanks for radio code info
volmvolvo850
Year and Model: 1996 850
Post by volmvolvo850 »
i found the radio code in the maintenance record book but still a no go..called volvo they verifed my code but still doesnt work..guess the radio was switched out?? also im a newbie on here and need help on how to respond and give thanks to those of you who posted replies----how do i do it?? thanks all...........oh yeah 1 more thiing the local european auto shop wanted $125 for an oil change------------i got 10-w30 full syn and a bosch filter,,,,but wheres the filter??
Mr-Glass
Year and Model: C70 2009
Post by Mr-Glass »
Maybe a dumb question - but have you tried pulling out the radio and checked to see if a shop or PO may have written the code on the label - I have done this on all my volvo's just a thought.. I have bought several that have already had the code written there as well...
volmvolvo850
havent tried that yet, thanks for the tip
FlyingVolvo
Year and Model: 2000 V70XC
Has thanked: 51 times
Been thanked: 73 times
Post by FlyingVolvo »
Never ever ever ever pay that much for an oil change!
Doing it yourself is very easy and you should only be spending about $5 for a good OEM oil filter + not much more than $30 for oil. Use a good full synthetic like Pennzoil Ultra or Platinum.
2000 V70XC - 340,000 miles
2023 V60 T8 PE
volmvolvo850
didnt pay for it got the oil and filter myself thanks
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 19 times
Post by jblackburn »
Filter is at the bottom right of the car - very easy to get to and twist off without using a wrench :)
'98 S70 T5
2016 Chevy Cruze Premier
volmvolvo850
thanks
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
If you haven't fixed your radio yet, pull it out and email me ALL THE NUMBERS ON THE TOP
in the order they're printed, (top to bottom, there should be 3 lines) and the model of your radio and I'll get you your code
jrl1194 (at)aol(dot)com
JimBee
Has thanked: 25 times
Been thanked: 42 times
Post by JimBee »
I also have 850 radio issues. The radio that came with my 850 —not installed— doesn't work when installed. How can I test it directly from the battery? Someone on this forum said the red wires are hot, black ground. I have solid black wires, but reds are striped, two different reds with different stripes.
