97 850 wagon axle shaft rattle
when im driving or just sitting at idle i get a rattle noise. I put the car on the ramps and slide under while it was running and found that the rattle was coming from the passanger side axle shaft. if i hung my hand on the shaft by the support , the noise would quit. I checked the support bolt and they were all tight. What else can I do? should i replace the axle shaft? could this be related to wheel bearings?
- Year and Model: Many Volvos
- Been thanked: 75 times
If the wheel bearings are loose enough to rattle you should be able to discern play in them. Jack up one wheel at a time and feel for slop. Bad wheel bearings normally start off with a roaring sound that changes pitch when cornering.
- 3346 Views
Last post by bluesguys80
- 4646 Views
Last post by SuperHerman
