94 850 turbo
brent61
94 850 turbo
Post by brent61 »
help w/ the oil consumption, i have been told my turbo is okay but the such and such needs to be replaced....can someone tell me ?
White850Turbo
Post by White850Turbo »
brent61 wrote:help w/ the oil consumption, i have been told my turbo is okay but the such and such needs to be replaced....can someone tell me ?
Have compression and leak-down tests been done on the engine? If so, what numbers were given from it? What weight of oil are you using? Dino or synthetic?
Guest
Post by Guest »
If test are run on the engine and all pass ok, you may have a clogged crankcase ventillation box which will cause oil consumption without seeing smoke out of the tailpipe. This is very common, especially if the oil isn't changed frequently.
