Right low beam out
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
pbansen
Right low beam out
Post by pbansen »
Hi list -
New member here. I have an '89 765. My right low beam has suddenly gone out. It's not the bulb or the fuse (replaced both with new ones). How likely is it that the relay would suddenly poop out with no warning? Any way to chech the relay using a standard VOM?
Other suggestions?
Thanks,
Pete Bansen
Truckee, California
pbansen
Post by pbansen »
Figured it out. It must have been the bulb after all, and maybe the fuse. I changed the fuse and checked with what I thought to be a good bulb - no light. Then checked the connector for voltage and, lo and behold, there was 13.8 volts at the connector, so I tried a different bulb and it worked.
Phew...
Now if I can just get the right seat "STOP" button unjammed (children just can't keep their sticky little hands off electric seat controls)...
Pete Bansen
Truckee, California
