broke gearshift lever
ryanv70
Year and Model: 1998 v70 xc
Post by ryanv70 »
someone broke into my car apparently they needed an ashtray to remove it they jammed the shifter out or the park position. now it is very hard to move and doesnt really click into d or r or p. is this easy to replace. the car is a 98 v70.
thanks
vjaneczko
Year and Model: 2006 S60R
Been thanked: 6 times
Post by vjaneczko »
You may want to pull the center console and determine what parts are damaged; could be the shifter, the lock or something just jammed in the way. I've seen a few shifters for sale on eBay and it probably isn't difficult to replace.
1997 855 GLT - R.I.P.
2006 S60R - For ME!
polskamafia mjl
Has thanked: 19 times
Been thanked: 21 times
Post by polskamafia mjl »
I'm thinking there may have been some serious damage done here. Take a look at the engine bay end of the shift cable and see if seem loose or if it is still tight.
To the right of those 2 bolts is the cable
This write up shoes you how to get to the cable -> https://www.matthewsvolvosite.com/forums ... =1&t=29930
