electronic throttle control Topic is solved
V70 fan
Post by V70 fan »
Hi
I have heard about electronic throttle control problems with 99-00 V70 models. Is it a common issue ? Is it a device that wears out with time ? Does it fail suudenly and how ? Can you anticipate the problem ?
Thanks you
Guest
Post by Guest »
Actually, the throttle you are talking about was used up until 2002. It can fail at any moment, but usually there will be a surge from the engine at idle and the check engine light will come on. It's not cheap to replace either. If you live in California or Massachusetts, it's covered under warranty until 70,000 miles.
