Stalls
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 19 times
Does the transmission feel like it smashes between gears rather than shifting smoothly or does the idle faulter as you pull to a stop?
You may want to check the trans. fluid - if it is brown/burnt, one of the solenoids may be sticking and causing your car to stall.
Otherwise, it may be the idle control valve is unable to react quickly enough to the load taken on/off on the engine between gears, and could probably just use a good cleaning.
'98 S70 T5
2016 Chevy Cruze Premier
- 4188 Views
Last post by Bluevanacd2005
- 1000 Views
Last post by jeffbecker5
