Which way should vac line check valve be oriented?
Stupid question, I know, but I'm almost done with a huge amount of work in the engine bay of my '01 V70; I'm replacing the vacuum lines with new silicone lines, but the problem is, I didn't think to check the orientation of the check valves (the two white plastic pieces in the vac tree coming off the intake manifold), and now I'm not sure which way they're supposed to go. Should the arrows point TOWARDS the intake manifold, or away from it? TIA.
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
Towards the intake.
'98 S70 T5
2016 Chevy Cruze Premier
Thanks so much; that was how I'd oriented them, but I was still having a really rough idle, and thought that maybe I'd messed up the valves' orientation. Turned out to be a faulty MAP sensor; replaced it, and now the car's running great!
- 22 Replies
- 4464 Views
Last post by kimothyanne
- 359 Views
Last post by rguzz
- 14 Replies
- 5914 Views
Last post by erikv11
- 176 Views
Last post by coop
- 184 Views
Last post by coop
