How to Remove and Re-install Internal Rear View Mirror
yangul
Year and Model: 1996 850 GLT
Post by yangul »
Hello Guys,
I was removing some hanging air freshener from around my review mirror when suddenly it got loose in its support. How can I remedy this issue?
Secondly, the odometer and trip counter are not working on my 1996 Volvo 850 GLT. How can I resolve this problem?
:o
Yangul
volvomileage
Post by volvomileage »
wlecome to mvs
there is an impressive load of information on almost any topic, you can use the serach within this site
heres for the odometer gear
https://www.matthewsvolvosite.com/2005/0 ... ix-how-to/
the rear view mirror is covererd in this write up
https://www.matthewsvolvosite.com/forums ... =1&t=26848
best of luck
volvo 850 95 sedan non/turbo 185 k
Pauloil
Post by Pauloil »
at oreilly's etc. they sell kits to superglue the little piece of metal in the stalk of the mirror back onto the windshield.
99 V70XC 158K
95 850glt 188K
BEJinFbk
Year and Model: '98 V70 R
Has thanked: 93 times
Been thanked: 146 times
Post by BEJinFbk »
Pauloil wrote:at oreilly's etc. they sell kits to superglue the little piece of metal in the stalk of the mirror back onto the windshield.
These are Roof mounted with a safety breakaway. A pretty good idea from these Volvo guys.
You may be able to remove the plastic cover with the map lights in it and pop it back into it's mount.
It looks like this inside:
Mirror spring mount.jpg (45.43 KiB) Viewed 12873 times
But, it's probably gonna be a real pain to replace while the mount is installed.
Those spings are pretty tight and it's not an easy reach for applying pressure.
You may have to resort to removing the mount, taking the cone-headed
screw out and putting it back together that way. Best of Luck! :wink:
nightc1
Year and Model: 99'V70 Base 140K+Mi
Post by nightc1 »
yangul wrote:Hello Guys,
IF the arm that holds the mirror is solid (doesn't move around) and the mirror is loose and wobbly... then unfortunately the mirror is shot and probably will eventually break loose. I had this happen on my 99 V70. I ended up ebaying for a mirror. I think it was something like $20 for a used one. I did some crazy stuff with superglue and rubber bands to tie me over until I bought the mirror... but I leave it to you to get creative if the mirror is the issue.
If the whole thing is loose... then yeah, it's a screw to adjust and that's it.
desoz
Year and Model: V70 1998
Post by desoz »
Hello,
I followed these steps and removed the mount, but I can't get the springs back in. Are there any tricks to this?
thanks
