My car runs fine but I am debating whether or not to replace the ECT.
For those of you who had ECT failure, what are the symptoms of bad ECT?
Engine Coolant Temp (ECT) symptoms
jblackburn
- Year and Model: 1998 S70 T5
- Has thanked: 9 times
- Been thanked: 20 times
Mine failed during the winter, and the engine took forever to warm up (bad thermostat) and eventually evolved into very hard starting - I got a huge puff of black smoke a few times, and rough warm running, and eventually I got a check engine light for it.
Generally the ECT sensor and thermostat go in pairs, so I advise changing both if you're going to.
'98 S70 T5
2016 Chevy Cruze Premier
meine39
- Year and Model: 1995 850 GLT Wagon
My defective ECT caused a Check Engine Light. No symptoms per se, since the CEL occurred at the same time that the radiator gave out. I replaced the ECT as part of the radiator replacement, as well as a new thermostat and upper/lower hoses.
Here's the Volvospeed/Bay 13 write up:
http://volvospeed.com/Repair/thermect.php
1995 855 GLT 190K NA Auto
1998 BMW 528im 137K
2000 Toyota Camry 78K
2010 GMC Acadia 57K
1998 BMW 528im 137K
2010 GMC Acadia 57K
KRUZNBY
- Year and Model: '94 855T Wagon 117K
I have a check engine light for my ECT as well. My temp gauge does not get above 4 o'clock, but that could be a thermostat issue. My car already has some other issues, so it is hard to say what are specific to the ECT failure for me.
'94 855T Wagon (120K)= Boost and a booster seat all in one.
Stage 0 in progress...
FlyingVolvo
- Year and Model: 2000 V70XC
- Has thanked: 51 times
- Been thanked: 74 times
A bad thermostat won't throw a CEL, so if you have a code for ECT, it more than likely is ECT. A bad thermostat simply won't let the car warm up very well (or if it's stuck closed, it will overheat).KRUZNBY wrote:I have a check engine light for my ECT as well. My temp gauge does not get above 4 o'clock, but that could be a thermostat issue. My car already has some other issues, so it is hard to say what are specific to the ECT failure for me.
It would be advisable for you to change both ECT and thermostat.
2000 V70XC - 340,000 miles
2023 V60 T8 PE
2023 V60 T8 PE
- 2512 Views
Last post by prwood
- 1348 Views
Last post by FLXC90
- 1320 Views
Last post by richardgengle
- 1704 Views
Last post by Kazthebassman
- 34 Replies
- 4523 Views
Last post by mikestr
