2001 XC70 Wont Start
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
schuyler_mason
Year and Model: V70XC, 2001
Post by schuyler_mason »
My Volvo died a week ago going down the road. Mechanic tells me bad ignition coil shorted fuse and recommends replacing all five. I've replaced all five as well as the fuse and car still won't start. Cranks fine, but just wont start. Is this characteristic of anything basic or am I going to have to tow the thing to another mechanic?
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2657 times
Been thanked: 1248 times
Post by matthew1 »
Did the fuse blow again? How reliable do you think his coil diagnosis was? Was he certain or is this a "throw parts at the problem" thing?
Also -> Amazon link
schuyler_mason
Not sure about the fuse. How does one tell if it's blown?
I've not been to this mechanic before and I'm not sure how he came about his diagnosis. The CEL has never come on and I've been unable to get any codes from the code reader. Although the mechanic came highly recommended, I just couldn't justify the $700+ to replace all five coils. He told me he could replace the fuse and at least get me running so I agreed. When I went to pick the car up, it wouldn't start. We replaced the fuse and it cranked right up. Drove it home and it died in my driveway and hasn't run since in spite of 5 new coils and multiple fuses. Is there something between the coils and the fuse that can be shorting?
Note below the correspondance from the mechanic.
"The issue is related to a high voltage load through the ignition circuit, the fuse blows due to a over load by a Coil or multiple Coils. I would think that a no start after replacing the fuse may be indicating that there are multiple coils draining the circuit of voltage to start the engine. I would start with known good replacement coils and test drive with diagnostic scanner to verify the repair."
matthew1
Site Admin
Post by matthew1 »
This is out of my depth. New coils and the fuse still blows... I just don't know where to go. Maybe someone here will see this and have ideas.
Also -> Amazon link
schuyler_mason
Thanks Matthew -
Is there any wisdom to replacing with a larger fuse? RIght now, there's a 20.
matthew1
Site Admin
Post by matthew1 »
Generally that's a bad idea -- assuming 20 is the correct, factory fuse load. It might get you off a lonely highway at night in an emergency, but the Volvo engineers put a 20 in there for a reason.
Later tonite and once or twice a day just type a new post in this topic -- even if it's the word "bump". That way the topic will bump (rise) to the top and will enter the rotating topics at the top of forum pages. That way it'll get more attention.
Also -> Amazon link
mrjacobrussell
Year and Model: 2006 s60R
Has thanked: 2 times
Post by mrjacobrussell »
I know its a old post but did you ever resolve this ??
2004 S60R AutoX Car
2006 S60R
2005 v70R
2006 v50 t5 AWD M66
2005 v50 t5 AWD for sale
I have a Chinese DICE, works well.
In southern Oregon.
