Denso TT spark plugs too long
eatcubensis
Year and Model: 850 t5r 95
Post by eatcubensis »
Hello. I am new to this forum (kinda). I went and bought some Denso spark plugs today. I get to the install and I notice that the boot will not sit all the way down on the spark plug. After closer inspection I notice that the Denso is slightly longer than the Volvo oem spark plug. Has anybody else had this issue? Can it be remedied or do I need to get different plugs?
vjaneczko
Year and Model: 2006 S60R
Been thanked: 7 times
Post by vjaneczko »
Well, you might try and cut the plugs in half . . . :lol:
Sounds like you got the wrong ones because the boot should fit snug on the engine. Did you get p/n PQ20TT? Their website indicates thats the TT model for your ride.
http://www.densoiridium.com/find_part.php
Oh, and welcome to the forum!
1997 855 GLT - R.I.P.
2006 S60R - For ME!
FCPEURO
Year and Model: 2006 XC90 V8
Been thanked: 19 times
Post by FCPEURO »
Definitely brought the wrong ones. I had these plugs in my 850 and the boot fit snug.
Also, to be honest, I was not a big fan of them. My 850 did not run as well with them as it did with the OEM ones. I ended up going back to OEM plugs in the end.
polskamafia mjl
Has thanked: 19 times
Been thanked: 21 times
Post by polskamafia mjl »
OEM or Bosch only for plugs...everything else, regardless of what they claim, will make the engine run poorly.
Allen in Hemet
Year and Model: 2000 V70XC SE
Post by Allen in Hemet »
I guess i'm the excemption to the rule. I installed some Denso E3's in my 2000 Volvo V70XC, and they helped the car start a little quicker and smoother. Although, I gotta admit, they don't seem to help with gas mileage or performance, but they haven't hurt it either. I am basicely getting the same gas mileage with the denso's as I did with the original Volvo plugs. But, Like I said, they do help getting the car started a little quicker, so they are staying in. R/ Allen
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 20 times
Post by jblackburn »
I went back to running Autolite Platinums in mine; the last set of Bosch's wore out way too quickly for my liking and started missing every time I went to merge on the highway.
'98 S70 T5
2016 Chevy Cruze Premier
GmanIV
Year and Model: 1999 V70 GLT
Post by GmanIV »
I am running Autolite Double Platinum in mine, runs great! I took out NGK copper, didnt notice any difference in performance at all. I say for your money, get the Dbl Plat, they will last longer than any plug and since it's platinum on platinum, there is virtually no gap wear. Irridium itself will last longer than Platinum, but those plugs spark onto metal, the metal part of the plug will wear out and thus making the gap big, wont happen with Double Platinums, easy 100,000 miles on them.
