96 850 Turbo Just installed Denso Iridium Spark Plugs
RussB
Year and Model: '00 S70, '04 S60
Has thanked: 3 times
Post by RussB »
SK20PR-L11 (3443) to be exact. I had been running Volvo branded platinum plugs for 11 years, never had an issue...until last spring. Bought a set from FCP in April, along with wires, cap & rotor. The car suddenly crapped out one day in May. It was running rough, throwing misfire codes. I could find nothing wrong. I had it towed to my favorite repair shop. They found one Volvo plug had a hairline crack and was misfiring. He installed one Denso Iridium (all he had that matched) and the car has been great for over a year.
I felt like changing the plugs "just because" and am now leery of the Volvo plugs, so I'm trying the overpriced Denso Iridium's. The Denso Iridium's came gapped at .044". I reset them to .028". I'll let you all know if they suck. 8)
'00 S70, '04 S60 and the never ending quest for Stage Zero
Year and Model: 2004 V70 2.5T
Been thanked: 466 times
Post by cn90 »
Denso Iridium has its own issues.
If you ever go with Iridium, stick to NGK. I posted the DIY for my 2005 XC90 2.5T below:
https://www.matthewsvolvosite.com/forums ... 10&t=64080
Has thanked: 1497 times
Been thanked: 3809 times
Russ - would you happen to still have that cracked plug? Interested for a work project.
RussB
Post by RussB »
cn90 wrote:Denso Iridium has its own issues.
What the Denso plug issues in the T-5's?
Like I said, my car ran a single Denso Iridium (albeit a SK20R11) for over a year in cyl #2. That plug was gapped at .042". Apparently the mechanic never re-set the gap to .028" (which I had to do with the new Denso Iridium's)
The only problems I ever had was with Bosch Platinum FR7DP (4028) which would misfire and throw codes under wide-open-throttle (WOT) with 12+lbs of boost. Took them out mighty fast
RussB
Post by RussB »
abscate wrote:Russ - would you happen to still have that cracked plug? Interested for a work project.
No, I don't. Like I said, it all went down over a year ago and my mechanic swapped it out. As a side note, he said that he sees new, defective/cracked plugs with some regularity. For the life of I can't remember which brand was worst (it wasn't Bosch, who I believe makes the factory Volvo turbo plugs for my car. They're marked Made in Germany)
northernlights
Year and Model: 850 Turbo 1994
Location: Florida and/or Raleigh NC, depending on the day
Been thanked: 8 times
Post by northernlights »
RussB wrote: I felt like changing the plugs "just because" and am now leery of the Volvo plugs, so I'm trying the overpriced Denso Iridium's. The Denso Iridium's came gapped at .044". I reset them to .028". I'll let you all know if they suck. 8)
I like the overpriced NGK Iridiums. Here's a link to a topic describing my experience with them in my 94 850 Turbo.
https://www.matthewsvolvosite.com/forums ... =5&t=62504
phat78ta
Year and Model: 94 850 turbo wagon
Post by phat78ta »
I run the regular ngk plugs in both my cars (when they actually run..) and have had nothing but great results. The 855 turbo that is making me hat volvo right now ran like a stabbed rat at @15 psi boost with no issues.
The plain ngk plugs are waiting for their home in the fresh rebuild as we speak.
93 850 GLT sedan 156K
94 850 Turbo 189K
Post by cn90 »
RussB wrote:...What the Denso plug issues in the T-5's?
Below is one anecdotal experience:
http://volvospeed.com/Review/performanc ... plugs.html
