ATF Oil
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
Esnoyer
Year and Model: V70 03
ATF Oil
Post by Esnoyer »
I have a V70 04 ,At a Volvo Only private service dealer I had a total ATF oil change, the oil was from a company called
Performances on the 5 gal containers, #244DMREBZ The dealer said they use it on all the Volvos,I checked and it is a Dexron 2E or 3 rating.. I understand that Toyota IV or Mobil 3309 is the norm, Should I change to these or go with what is in it now??
Any thoughts or suggestions??
JDS60R
Been thanked: 3 times
Post by JDS60R »
With proper friction modifiers certain ATF's can be made to perform within JWS3309 spec.
From what you have said the ATF used was not JWS3309 spec.
I included you owners manual and the Volvo spec sheet for reference.
If the repairer can not show that the oil is performing at JWS3309 spec they should replace it with the proper oil. In your case the proper ATF is JWS3309. If you have the option between a synthetic and non synthetic JWS3309 oil I would recommend the synthetic.
v70_2004.pdf
(6.63 MiB) Downloaded 285 times
Retired
paulhetty5
Year and Model: 2001 S60 2.4T
Post by paulhetty5 »
I would use AMSOIl ATF as its Full Syntheic and they will stand behind it. It meets all requirements. I found out that Mobil ATF 3309 is regular oil base and after writing Volvo there oil is Semi-Syntheic. I have been using AMSOIL in my S60 2.4T for 15k now with no problems and the oil is still red in color. I also agree that you should have the oil change out if it does not meet the requirements. These transmissions have special parts inside of them that require special oil.
JDS60R
Post by JDS60R »
+1 on Amsoil ATF
Retired
jjaV70T
Year and Model: V70 2.4T 2003
Post by jjaV70T »
I think they made a mistake, 3309Mobil, one case is $100.00, flush it yourself ,,posts here about the process, I have done it using 3309 Mobil @ 89K miles, BEST!
.2003, V-70,. 2.4T, 101,100K..
.1985, 245T,.sold at 280K....
.1974, 145, sold at 250K....
Retired MVS Contributor
Post by Retired MVS Contributor »
jjaV70T wrote:I think they made a mistake, 3309Mobil, one case is $100.00, flush it yourself ,,posts here about the process, I have done it using 3309 Mobil @ 89K miles, BEST!
Mobil 3309 ATF is $51 and change per 12 quart case at avlube .com
