Dear all,
When I drive on bad roads, road bumps etc at different speed I have lately experienced irritating noices from the rear of my car. I assume it
Rear shock absorber problems on S60? Topic is solved
Guest
I have an 01 S60 which does the same thing. Apparently there was a recall for that problem. There were faulty clips in the tops of the shock towers.
Anyway, check with your dealer about the recalls.
Hi, I am a new member who just purchased a used 2002 S60 Volvo. Iam experiencing the same noise in th right rear of the car. It seems as though it is coming from the shock/strut area. Did you get your problem solved and if so by what method? Thanks Crow
