940 Rear Shock Absorber - Rubber Washer
Metallo
Year and Model: XC 70 AWD 2.5 - 2006
Has thanked: 7 times
Been thanked: 6 times
Post by Metallo »
Hi all,
Today I was replacing my rear shocks, the rear right one was easy, the rear left has been a big pain so far.
To make it short, I had to cut it with a grinder to remove it.
As a result, I had to cut both lower anti-vibration rubber washers.
The new shocks I purchased are the Sachs Advantage 106491 (Volvo P/N 1329500) and they were supplied without new rubber washers.
I launched VIDA and searched for those washers, no trace of them, which means they are not supplied.
I am stuck as it looks impossible to find those washers anywhere, I have spent the last two hours on the internet, there is nothing even close that I can use to replace them.
OD: 1" ID"5/8 Thickness:3/8
Any ideas?
Thank you!
Alex
Polar 940 Turbo SW - 1997
93Regina
Year and Model: 93:240/940
Been thanked: 65 times
Post by 93Regina »
Metallo wrote: 14 Apr 2018, 13:49 OD: 1" ID"5/8 Thickness:3/8
Bilstein 19019888 may include them
"rubber grommet" is not a good search term. Here's a perfect fit, but filling in that groove is the issue....maybe a washer could be slid in that groove
rubber washer OD: 1" ID 5/8" Thickness 3/8" sort of works.
Here's something I found, but I'm not sure about its firmness. OD is a pinch short, but if you can find these locally, you might take a look...
Metallo
Post by Metallo »
Thank you, tomorrow I will go and see Fastenal, I hope to find actual rubber 'doughnut' more than grommets!
Alex
93Regina
Post by 93Regina »
Metallo wrote: 16 Apr 2018, 17:43find actual rubber 'doughnut' more than grommets!
I think that grommet had a 1/8" slit in it...if fairly firm, a washer of this size might be embedded.
Chances are, someone makes actual doughnut, you might even ask Bilstein
